Reliability with gen 4?
Discussion in 'Gen 4 Prius Main Forum' started by stephensprius, Dec 23, 2019.
  1. stephensprius
    stephensprius Active Member
    670
    226
    Minneapolis, Minnesota
    I know it’s a fairly new model generation. After reading an article today about the new RAV4 hybrid issue with the fill up of the fuel tank, I was just curious if there are any issues that folks are facing with their 2016 and newer with the Prius. Thanks!
  2. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,593
    near Brisbane, Australia
    Nothing much here. I had an issue when mine was new with the Brake Light Switch which caused multiple Malfunctions to display - but that was fixed quickly. It's achieved commendable results for quality and reliability on various surveys etc around the world.
  3. husami
    husami Junior Member
    50
    Cincinnati, Ohio
    I have had mine for 6 months now with no problems at all
  4. stephensprius
    670
    226
    What years do you both have?
  5. alanclarkeau
    7,045
    7,593
    It's in the profile to the left.
    stephensprius likes this.
  6. Tyfly
    Tyfly Member
    65
    94
    I currently drive a 2017 with about 62,500 miles. I got it in April 2017 with 14 miles.
    Around 50,000 I had condensation buildup in the passenger-side headlight. The headlight was replaced under an extended warranty I purchased.
    Other than that, not one thing has gone wrong. It’s been as reliable as I’ve come to expect from Toyota, and more reliable than the two Subarus I owned before the Prius.
  7. priusman09
    priusman09 I used to be a TDI
    67
    76
    wisconsin
    All you need to do is check out Comsumer Reports Magazine to see that Prius continues on with it’s stellar reliability record. On my second Prius (‘17 Prime) that continues to prove why I switched from VW to Prius since 2009. Simply Amazing
    krmcg likes this.
  8. bestmapman
    bestmapman 04, 07 ,08, 09, 10, 16, 21 Prime
    1,289
    242
    Kentucky near Cincinnati, OH
    2016 85,000 miles. Only issue is 3 replacement windshields.
    m.wynn and krmcg like this.
  9. esfishdoc
    esfishdoc Junior Member
    26
    45
    ESVA
    2017.. about 89,000 miles. No issues. Still can't find the self clean cycle button.
    DicedPixel and krmcg like this.
  10. Seamaster
    Seamaster Member
    123
    70
    GB
    2019 Prius
    Excel
    2019. Been good as gold. And MPG beating expectations.
  11. sclevine
    sclevine Active Member
    170
    160
    Northeast Florida
    2024 Prius
    111,000 miles on my 2017 and it's been the most reliable car I've ever owned.
    Only issue I've had is occasionally 2 of the automatic door locks stop responding. Stops working for awhile (few days, or few weeks) and then eventually starts working again. Have to work the locks manually if they stop responding. Super annoying when it is driver door lock :)
    Will get it fixed eventually, but it is approx $500 per door.
  12. stephensprius
    670
    226
    Wow. 117k miles!?! What do you do for work? That’s a ton of mileage.
  13. royrose
    royrose Senior Member
    1,389
    953
    Foot of Pikes Peak
    A Toyota spokesman recently stated that the fueling issue in the Rav4 hybrid may be related to the "saddle" shape of the gas tank. So it appears that the problem is specific to the Rav hybrid (including mine). They still do not have a fix.
  14. Tande
    Tande Active Member
    553
    339
    Mich.
    My Gen. 4 has had Zero issues (2017-1/2)......puts a smile on my face, every time I close the door, going or coming! ......
  15. Striker325
    Striker325 Junior Member
    25
    24
    Los Angeles
    2016 Toyota Prius 32k miles
    Just have the axle click noise when using brake regen at low speeds.
    Other than that amazing. I am averaging 65-66 mpg.
    Mambo Dave likes this.
  16. ice9
    ice9 Active Member
    581
    346
    norfolk va
    2018 Prius
    2019, going on 7,000. So far so good. I have a minor rattle in the rear of the vehicle whenever I hit a bump. Suspect it's the hatch latching mechanism.
    Also there is this: To me this looks like a corrosion issue, but I am not a gearhead so I wouldn't know whether or not this is normal. Can anyone comment on the level of corrosion in the zoomed image?
  17. Striker325
    25
    24
    Los Angeles
    I can relate to that corrosion. I believe that bolt is not anodized or coated so the environment is being harsh on it causing corrosion. Not sure if there is an alternative part.
  18. ice9
    ice9 Active Member
    581
    346
    norfolk va
    2018 Prius
    Thanx. To me the corrosion seems excessive. However, it might be acceptable for the application. I guess a more pertinent question is "what would be the consequences of not doing anything about it?"
    I am thinking about coating it with poly-sulfide to help mitigate exposure.
    alanclarkeau likes this.
  19. kithmo
    kithmo Couch Potato
    2,404
    2,776
    47
    South Yorkshire, UK
    Spray some WD40 on the bolt.
    ice9 and alanclarkeau like this.
  20. ETC(SS)
    7,515
    Maybe clean it a little first.
    Monitor as before.
