reliability
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by chronon, Apr 7, 2021.
  1. chronon
    chronon Active Member
    601
    106
    here and there aint be in frozen wasteland no mo..
    Hello .. just wondering about the C .. heard 'dont get the gen 3 ' .. ESP the 1st 3 yrs of it ..
    is the C prone to the same issues as prius gen 3 ?
    thx
  2. PriusII&C
    PriusII&C Active Member
    432
    147
    San Jose, California
    What problems? As far as I know, most Gen-3's and C's don't have major problems up to now. Some Gen-3's consume some oil after 150k miles, give or take, if that is what you refer to. Another concern is EGR circuit clogging, but its relation with reliability is not established yet...
    chronon likes this.
  3. PriusCamper
    PriusCamper Senior Member
    13,459
    5,430
    Pacific Northwest, USA
    Lol, you said they don't have any problems and then you accurately listed the vehicle's primary problems...
    chronon likes this.
  4. chronon
    601
    106
    SSOME oil consumption .. (*ie 1 qt per mounth or 1000 miles) is not bad .. not great but i think most would find that tollerable if that is what the consupmtion level is .. old corrollas have that reputation already ...
    I did hear about EGR clogs when the car doesnt get the full warm-up cycle .. and idont know how bad it makes the operation of the car ..
    i have heard about oil rings and pistons and cylinder heads and head gasket replacements .. those are the things concerning me ...
    and water cooling warpages ?
    I guess we can add Vibration issues is engine compartement as another problem:
    #4 chronon, Apr 7, 2021
  5. chronon
    601
    106
  6. topshot
    topshot Member
    154
    58
    Midwest
    2015 Prius c
    I've never read of inverter failure being an issue for Gen 3. I'd also say 2010-2012 rather than 2013. Nevertheless, the c doesn't have the EGR or headgasket issues. It seems the main complaints I've seen have been door locks and water in taillights.
    kdfchannel and chronon like this.
  7. PriusCamper
    13,459
    5,430
  8. kdfchannel
    kdfchannel Junior Member
    59
    17
    Orlando, FL, United States
    I bought a prius C with 150k miles no running
    It had a clogged egr and intake
    Suffered hydrolock cylinder 1 (head gasket failure) I replaced the engine
    Bad 12v battery
    Bad HV pack
    But to be honest since I am doing all this maintenance I can tell the prius C is well built and is really fun to drive I've had 2nd and 3rd Gen prius but this one is agile the 1NZ won a lot of awards to be honest is a interesting car if you do maintenance as soon as you buy you should be good.
    Pri3C and chronon like this.
  9. PriusII&C
    432
    147
    Do you have a writeup or video showing how to clean the EGR?
  10. chronon
    601
    106
    a -small price to pay indeed for the exc. economy on the wallet at the pump !!!
    kdfchannel likes this.
  11. kdfchannel
    59
    17
    I just uploaded a video on youtube, so you can take a look how I did it .
    mikeey01nzl, Pri3C and chronon like this.
  12. kdfchannel
    59
    17
    hahaha I forgot to mention I have both of those problems.
  13. PriusII&C
    432
    147
    Is that your video? Nice. It would be even better if you could record how to take both the valve and cooler off.
    Pri3C and kdfchannel like this.
  14. kdfchannel
    59
    17
    Yes that's my prius I did that video today the cooler is a pain in the nice person to remove basically is easier if you remove the wiper assembly and the plastic cover, the egr cooler is attached to the exhaust and you have to loose some bolts to make it easier to remove,but to be honest when I cleaned the cooler a lot carbon came out.
  15. Sonic_TH
    Sonic_TH Active Member
    575
    96
    Puerto Rico
    2016 Prius c
    How did the previous engine of your Prius C died?
  16. kdfchannel
    59
    17
    yes sir one I cleaned the water inside the intake manifold and inside the valves the car turned perfectly but it had a rod noise I found a new engine with 40k miles for $300 so I decided to go that way instead of fixing the old one with 160k miles
    Sonic_TH likes this.
  17. Sonic_TH
    575
    96
    Puerto Rico
    2016 Prius c
    160,000 miles is very low for a Toyota engine to fail, specially a Prius C engine. Was your car in a flood? since there was water in the intake manifold.
    PriusCamper likes this.
  18. kdfchannel
    59
    17
    I think it suffered from hydrolocking due to a failed head gasket never taken care of, that's what I think but I wish I had time to open the engine and check what was goin on but this video was before I opened the intake to discover I had water in it
    and then this video is when I cleaned the water from the cylinder and intake
  19. Sonic_TH
    575
    96
    Puerto Rico
    2016 Prius c
    That's weird, maybe the engine water pump failed, causing your engine to overheat and then destroy the head gasket? Well at least your Prius is running now, but replacing an engine is not easy nor cheap, and i think is something quite difficult to do, i would not feel the same with the car if such thing ever happens to mine
  20. kdfchannel
    59
    17
    I agree maybe that could be a reason the water pump. but I found the engine for $300 6 month warranty and 40 K miles salvaged car. yes is difficult to replace it but everything I considered to be a learning lesson, for sure somebody to fix the actual engine would be $500 + and I saved a lot just because I replaced it myself , I couldn't scape from somebody stealing my money a "technician" charged me $350 to fix the battery pack and back then I didn't know anything how to recondition de HV battery and he just replaced 2 modules without cycling balancing or whatever I put the battery back after few minutes I got the triangle again. so if some member watching this be careful orlando area fake technicians fixing batteries.
