Relooking at warm-up
Discussion in 'Gen 3 Prius Fuel Economy' started by bwilson4web, Sep 17, 2013.
  1. bwilson4web
    16,533
    So I was able to capture a full, miniVCI monitor of all engine ECU metrics during a warm-up cycle:
    • "Request Warm-up" - went from "1" to "0" state, engine stopped within 3-4 seconds.
    • "Catalyst Temp B1S2" - went from 103.4 to 105.8, this may turn off "Request Warm-up"
    • "Coolant Temp" - went from 40C to 41C, it may also turn off "Request Warm-up"
    My earlier tests with the 1.5L, 2003 engine and spoofing the coolant temperature showed 40C was the threshold between reliable engine operation and 'choking when cold.' So I'm leaning towards the coolant temperature as the threshold that stops the "Request Warm-up".
    I'm still looking at the nearly 75 columns of metrics. I'm still trying to understand vehicle fuel consumption as a function of these various metrics. This not trivial.
    edwardob and hybridbear like this.
  2. edwardob
    edwardob Member
    227
    33
    ireland
    great work.................................. looking forward to your observations
    hybridbear likes this.
  3. Maxwell61
    Maxwell61 Active Member
    393
    242
    Italy
    2024 Prius Prime
    XSE Premium
    As long as you don't assume this coolant temp beeing 40C.
    In actual fact, "Request Warm-up" can return "1" and the car be in the midlle of an S1 at 70C, as i measured yearstday in Torque, just because you stopped the car for a while, even if the engine is warm well above 40C.
    So i guess the catalyst temp has something to do anyway...
    bwilson4web likes this.
  4. Maxwell61
    393
    242
    Italy
    2024 Prius Prime
    XSE Premium
    Bob, testing today with Torque an S1 made entirely in motion, and with some slight acceleration in it, i found an upredicted behaviour that could be relevant to the discussion.
    If you look at the area markd as "???" you'll find, in the middle of S1a, an abrupt inversion of Timing advance and a relative fall in the current from the battery. Unfortunately the 1 sec delay time of the data collection does'nt make it very clear, but i see a definite pattern of ICE collaboration.
    What will happen if the acceleration was the flooring as mentioned in this thread?
    I think this is interesting beyond the scope of the thread, cause potentially can make you confident that you can make it out of steep ramps, even in S1a....
    Speed in km/h ; current in Amp ; SOC in %, Timing in Deg.
    Comments appreciated.
  5. hybridbear
    hybridbear Member
    267
    69
    Minneapolis
    Great data! The other day I tried flooring it while in S1a to see if I could get the car to leave S1a. Even with the power demand filling the PWR area on the display the ICE timing stayed negative and under a low load. The HVB provided all the power, showing about 125 amps of discharge to accelerate during that time. I only held my foot down for 1-2 seconds because I was on a residential street and didn't want to damage the HVB discharging so rapidly.
    When I performed this test the car was relatively warm from running errands, but just cool enough to require S1a upon starting.
    Maxwell61 likes this.
  6. bwilson4web
    16,533
    This morning was cool, 13C (55F), so I hooked up miniVCI and recorded four data segments, ~2:30 minutes each:
    1. 0-160 seconds - cold-soak, initial run until engine stopped
    2. 180-340 seconds - neighborhood 25 mph speeds, often in "N" to reach cross street
      1. due to traffic, long delay before next segment
    3. 360-520 seconds - cross street, 50 mph, multiple overpasses
    4. 540-700 seconds - access street, ~40 mph, coasting to light
    I've attached a CSV file, typed ".txt" with the raw data. Feel free to download and look for interesting relationships.
    • Before the engine starts, the engine controller reports the last catalytic converter temperatures. Once the engine starts, it begins reporting the accurate temperatures.
    • The engine coolant start rising along with the catalytic converter temperatures:
      • 40C - coolant
      • 370C - O{1} sensor temp
      • 260C - O{2} sensor temp
    • After backing out of the driveway, 19-25 mph to the cross street
      • 40->55C - coolant climb
      • 350->480C - O{1} sensor temp
      • 250->350C - O{2} sensor temp
    • Obviously the vehicle warm-up still continues in the first mile to reach the cross street
    • About 5 minutes later, the approximate gap, the coolant and sensor are approaching operational range
      • This is why a good rule of thumb is the first 1-2 miles are at ~30 MPG, the warm-up cost
      • Once cruise speed and warm-up achieved, the car is doing +50 MPG (assuming properly prepared)
    • Coasting down and with the engine mostly off, cool-down begins
      • The slopes can be used to predict how long it takes to be in warm-up mode
    These temperatures are at the end of the catalytic converter. These signals really signal when the car has reach full-warm-up.
    Enjoy!
    Maxwell61 and edwardob like this.
  7. edwardob
    edwardob Member
    227
    33
    ireland
    so at this point the question remains
    so what can we hack to outwit the sensors[and toyota engineers]
  8. hybridbear
    hybridbear Member
    267
    69
    Minneapolis
    Can I see this same catalyst temp data on the ScanGauge?
  9. bwilson4web
    16,533
    How about looking at the amount of fuel burned as a function of the engine power in the four different modes?
    We already know the warm-up fuel burn is independent of "N" or "P" but shorter duration in "P". So the next variable is whether tricking the engine to running in "N" for a few more minutes results in a fuel savings during the neighborhood, 25 mph, exit. What are the numbers?
    We get a baseline and then 'do the experiment' so we have facts and data.
    edwardob likes this.
  10. edwardob
    edwardob Member
    227
    33
    ireland
    will be really useful for those who stop/start motoring a lot or short journeys...to improve mpg
  11. Agent J
    Agent J Hypoliterian
    294
    111
    Sydney, Australia
    Interesting thread here even just scanning through the posts quickly... i'll have to read it again 2 or 3 times to digest it thoroughly.. :p
    Just my .002 gal worth, the only way to skip S1a is to use an engine block heater so that coolant temp will reach above 50C (in warm climate) so one can drive off right away in S2. In cold weather, the highest I saw was about 45C and i think it just took me to S1b. But still, S2 wasn't far away.
    This will decrease the amount of fuel burned, but will increase your power bill a bit depending on the cost of electricity. :D
  12. edwardob
    edwardob Member
    227
    33
    ireland
    even with engine block heater the CAT has to warm up....which is part of s1a ibelieve...but it is quicker and cost of electricity is cheaper than petrol burned
    fooling the CAT is the way to go.....not good for emmisions...but burn less fuel[more green??]
    maybe..maybe not????
  13. Agent J
    294
    111
    Sydney, Australia
    haven't really experienced S1a-like behavior in the ICE when coming from a 50C coolant start up using the EBH. S2-S4 is just like the normal S2-S4 behavior if coming from a cold start. O2 sensors might be warming up but already giving correct signals based on coolant temp as interpreted by the ECU (?)
  14. edwardob
    edwardob Member
    227
    33
    ireland
    suppose what i mean is the engine will come ON even with the temp 50C
    so with stop/start driving....as i do deliveries.......this initial start up comes even at 60C IF IT BEING LEFT long enough
    so the CAT must be cooling a lot[mmm...idea for insulation on some of them pipes underneath!!]
  15. GasperG
    GasperG Senior Member
    1,169
    601
    Slovenia
    2018 Prius
    I don't think the CAT is cooling that quickly. In the morning after <5 min drive I stop at kindergarten, the engine completes it's warm up and is off. I normally leave the car in ready state, because if I turn it off I'm facing another warm up cycle (it is shorter, but still), but if I leave the car for <5 min in ready state, it doesn't go into warm up.
    bwilson4web and hybridbear like this.
  16. edwardob
    edwardob Member
    227
    33
    ireland
    i did'nt mention how long i stopped for>>>>>>.
    could be 15-20 mins
    but as you yourself say if you turn it off ..it WILL have another warm up cycle
    anyway....why? does it go into warm up cycle even if stopped short time and engine is still 60C or so
    is it the CAT that needs it or the engine?...or does it just do it
    [does the car doors lock in ready mode...never tried it myself...could be useful on some of my stops..to stop warm up cycle]]
  17. GasperG
    1,169
    601
    Slovenia
    2018 Prius
    No you can't lock the car in ready mode, when the engine is warm enough (80-90 C) it won't do another warm up, but winter slow city driving the engine coolant is below 60 C.
  18. edwardob
    edwardob Member
    227
    33
    ireland
    so back to where we started!
    so it's the CAT making most of the demands
    since even on cold morning ..once it reaches 40C initially engine will shut
    but later even if engines has cooled to 50 - 60C from 80-90C.....engine will start a cycle ... so something is requesting it!
    i don't have the gadgets to check these .....so maybe bob or someone has
    might be helpful in knowing why stop/start gives such an mpg hit!
  19. Agent J
    294
    111
    Sydney, Australia
    it could well possibly be.. however, i haven't experienced this phenomenon before where the ICE will do another warm-up cycle when the coolant temp falls to around 50C. perhaps your SOC was low at those times to warrant a charge cycle not a warm-up cycle?
  20. Maxwell61
    393
    242
    Italy
    2024 Prius Prime
    XSE Premium
    Could it be because the pressure on the pedal did'nt lasted enough time? For this particular situation i guess one have also to take in account the SOC: mine was at a rather poor 48%, it could be possible that before let ICE breaking in, the max output form the battery is taken in account.
