Reluctantly forced to sell on
Discussion in 'Generation 1 Prius Discussion' started by Mark6868, Aug 16, 2018.
  1. Mark6868
    Mark6868 Active Member
    118
    131
    London
    2001 Prius
    Hello all.
    My Gen 1 is coming up to three years old now. Just over 91k on the clock. I have kept it serviced via a Toyota main dealer who does good servicing rates for 'older' cars.
    However in the last month I have noticed a very loud roar from the rear, and suspect it is the wheel bearing. Ridiculously I got a quote from Toyota (UK) or £150 to plug into a diagnostic machine (is there a sensor on the wheel bearing?) and then £450 per wheel!! I am not paying that.
    No problem I thought. I'd go elsewhere. After calling about six or seven other places not one of them will touch it, citing they can't get the parts, or they don't have the tooling. Various reasons. I asked about brakes and exhaust replacements. But no they would not entertain touching the car at all.
    I got to thinking that any future work that needs doing on this car will cost me a small fortune at the dealers. There is no repair network in the UK for these Gen 1 cars. Even Prius specialists will not touch it.
    Alas, I can't keep it with the fear that any repairs would cost more than the car is actually worth. I couldn't believe the wall of rejection I received from various outlets with regards to this car.
    The UK does not like the Gen 1 Prius. A crying shame as I love it.
    Do any other Gen 1 owners in the UK (or anywhere else) have this problem?
  2. vaughnstark777
    191
    33
    Roy, WA
    2001 Prius
    I
    Mark6868, Brian in Tucson and MDNHW11 like this.
  3. Mark6868
    118
    131
    London
    2001 Prius
    Thank you Vaughn.
    I can get the parts in the UK (no problems) but nobody is willing to undertake the job (apart from main Toyota dealer) The main reason they give is lack of parts, so that makes no sense at all.
    It's very frustrating.
  4. Brian in Tucson
    Brian in Tucson Active Member
    981
    453
    Tucson AZ
    2003 Prius
    If you can't do the work yourself, you are correct to get rid of it. Get something newer but still clean running. Any maintenance on old cars can eat you alive.
    Mark6868 and dubit like this.
  5. Mark6868
    118
    131
    London
    2001 Prius
    You are right Brian in Tucson. I love the car, and this is the first problem in three years.
    I have two more places to visit tomorrow, but one has already told me they don't think they have the correct tools.
    Some places in the UK will not even put new tyres on a Gen 1 Prius. No idea what that is all about.
    Would plugging a Gen 1 into a diagnosis machine bring up whether or not a wheel bearing was failing?
  6. Brian in Tucson
    981
    453
    Tucson AZ
    2003 Prius
    Mark, the rear axle is pretty conventional and is the same or similar to other small Toyota front wheel drive cars. Hondas, Nissans, & Mazda/Fords, too. Nothing magical, no special tools required. Anyone that can work on a Corolla, Matrix, Echo, etc. can do the hubs and brakes. On this stuff, at least, find a hungry foreign car repair shop and ask them to have a look.
    Or if there are any automotive trade schools in London or the surrounding areas, take it to them and let some students learn on your car with the supervision of an instructor.
    mroberds and Mark6868 like this.
  7. Brian in Tucson
    981
    453
    Tucson AZ
    2003 Prius
    No. The only sensors on the axle are the ABS sensors.
    Mark6868 likes this.
  8. Mendel Leisk
    42,345
    Closest I've got is second gen rear wheel bearing removal/install, from the Repair Manual. Appreciate the devil is in the details, breaking loose the bearing. Anyways:
  9. Brian in Tucson
    981
    453
    Tucson AZ
    2003 Prius
    Looks pretty conventional to me. It would also be a good time to renew the brakes and maybe install new struts. I have to force myself to remember that for someone with no mechanical ability, this all looks like Russian or Greek. For anyone with a smidge of experience, this all looks pretty easy. The rear hubs can be replaced as a unit.
    mroberds, Mark6868 and Mendel Leisk like this.
  10. vaughnstark777
    191
    33
    Roy, WA
    2001 Prius
    I
    No special tools needed. The hub and bearing come as an assembled unit with the ABS sensor. It takes about an hour.
    If you don’t have an independent mechanic in the UK that can do that then I would suggest you stay away from used cars period! I would be very surprised if that is truly the case though. It is literally easier to do rear wheel bearings than to do rear brakes on a gen 1.
  11. vaughnstark777
    191
    33
    Roy, WA
    2001 Prius
    I
    This is a screenshot from my alldataDIY online subscription. It is available to anyone in the world with a WiFi connection for $45 USD per vehicle for a 5 year term.
    Any independent shop worth it’s salt will have the professional version that has access to all makes and models that they pay a yearly fee for.
    Take this info and the eBay info and go hunting for a shop, there’s got to be one within 50 KM of you:
  12. padroo
    padroo Senior Member
    2,763
    2,253
    Any real mechanic would take that job. Find a real mechanic. Drive across the English channel, they may speak a different language about the repair.
  13. Mark6868
    118
    131
    London
    2001 Prius
    Thanks for the advice Brian.
    I have now found a place that will tackle the job. I had to travel 45 miles outside of London only to be told the guy is on holiday. So a week's wait, but they will do the job and will firstly diagnose the problem. After all I am only assuming it's a bearing. I hope it is as the alternative doesn't bear thinking about.
  14. Mark6868
    118
    131
    London
    2001 Prius
    Thanks for clarifying. That makes my Toyota dealer a liar. They wanted £150 to plug it in to check if it is a bearing problem or not. I told them to just drive it, but they said it needed plugging in. I shall be finding alternative service premises.
    mroberds and Raytheeagle like this.
  15. Mark6868
    118
    131
    London
    2001 Prius
    Thanks Vaughn. Now I have found a place that will entertain me, I'll certainly mention the ABS sensor.
    Sod's law the 90 mile round trip today was as smooth as silk. No rumbling at all. :mad: .... when it runs like that it's a wonderful car to drive.
  16. Mark6868
    118
    131
    London
    2001 Prius
    Thank you again. I am going to print this thread off and take it to the mechanics when I return next week.
    Also whilst looking through the papers that came with the car, I found the following.
    Prius - Technical Reference Guide
    Toyota Prius 2001 Haynes Repair Manual
    Toyota Prius Repair Manual Supplement
    I shall be taking these with me and offering them to the mechanic (should he require any help) I hope he doesn't take offence, I may leave them on the passenger seat.
    Thanks to everyone again. You have all been very helpful. :):)
    Raytheeagle likes this.
  17. Brian in Tucson
    981
    453
    Tucson AZ
    2003 Prius
    Hope you can get it resolved. A mechanic shouldn't even need a manual to diagnose the rear end rumble.
  18. Brian in Tucson
    981
    453
    Tucson AZ
    2003 Prius
    We do try.
    Mark6868 and Raytheeagle like this.
  19. Mark6868
    118
    131
    London
    2001 Prius
    An update.:)
    It was the wheel bearing that had gone. The rear right side. The place I found replaced the hub and the car is back to being a pleasure to drive again. He had a devil of a job getting the old hub off as it was unbelievably corroded (18 years worth) and he didn't want to damage the back plate, so he had to take his time. The car is running so smoothly now. I must have become accustomed to that roaring noise, as I had forgotten just how quiet it can be!
    I also paid three times less than the amount Toyota wanted. So glad I started this thread. I was ready to get rid, but you guys made me realise it was not such a big job. So thank you all.
    One last question. When I got the car back I noticed the battery had been disconnected as all my pre-set radio stations had gone. Is the battery disconnected as a matter of course, or maybe something to do with the ABS sensor being replaced?
    Very happy to have my old car (and it is old) back in tip top working order. :D
  20. Mendel Leisk
    42,345
    With any Prius brake work it's good practice to disconnect the battery.
    ITBland and Mark6868 like this.
