Reluctantly forced to sell on
Discussion in 'Generation 1 Prius Discussion' started by Mark6868, Aug 16, 2018.
  1. Mark6868
    Mark6868 Active Member
    118
    131
    London
    2001 Prius
    Thank you Mendel.
  2. Mendel Leisk
    42,347
    I was a bit terse: basically they have to pull the brakes to get at the bearings, and with the battery connected you run the risk of a brake piston being pushed out, if the pump activates. Opening the driver's door it's a near certainty that'll happen. And also, after reassembly, it's good to pressure up the brake pedal before reconnecting the battery, so the car doesn't (possibly) detect excessive pedal travel, throw a code.
    Brian in Tucson and mroberds like this.
  3. Brian in Tucson
    Brian in Tucson Active Member
    981
    453
    Tucson AZ
    2003 Prius
    Good news! Yes, they are great cars. Hope it lasts a long time for you.
