Remote A/C retrofit
Discussion in 'Gen 3 Prius Technical Discussion' started by 4md, Mar 29, 2018.
  1. 4md
    4md Member
    97
    55
    Sofia, BG
    Hello everyone!
    My Prius doesn't have remote engine start, remote AC or solar roof. I'm wondering if I purchase a key with AC button and program it, it will start the AC? I've been searching about this, but I couldn't find an answer about replacing the regular key with the one with an AC button, sorry if I'm duplicating a discussion.
  2. qdllc
    qdllc Senior Member
    1,377
    400
    I went with remote start because I live where I more need to heat up the car and remote A/C does not run very long or heat a car. Presuming that your model Prius automatically turns on the heat or A/C when it powers on (if you leave it on Auto), a remote starter from Toyota would be the most seamless upgrade.
    52,848
    do they have keys with a/c on them for gen 3? the pip has one, but only when plugged in i think.
  4. qdllc
    qdllc Senior Member
    1,377
    400
    Don’t know. Remote start uses standard fob. It’s a sequence of button presses that activates the car.
  5. 4md
    4md Member
    97
    55
    Sofia, BG
    I thought the remote AC is available with every Prius which has the solar roof and not limited to PIP?
    qdllc, I like the idea of remote start, the temps here go below -5*F (-20*C) sometimes in the winter. I'm watching for ebay auctions or good deals, but those listings are very few and I'm too cheap and don't like the idea of spending $200-300 for this option :D
  6. bisco
    52,848
    oh, that's right, good point.
  7. qdllc
    qdllc Senior Member
    1,377
    400
    Well, for me, the remote start was way better an option. Remote A/C only ran for a few minutes and/or until the battery level dropped so far. Remote start will run around 10 minutes and heat or cool the car.
    It was $800 added when I bought the Prius new (although Toyota indicated the price was $500), but still...the best money I’ve spent.
    Aftermarket versions might be cheaper, but make sure they guarantee compatibility with your year and model.
  8. fotomoto
    fotomoto Senior Member
    5,639
    3,815
    So. Texas
    I don't know.
    I had the auto-ac feature on my solar roof option gen 3 and was the reason I purchased that trim level. IF this would work at all, you'd need at minimum a NEW fob as a used one shouldn't be able to seed with the cars' SKS system. A long search of the factory manual would be needed to see how involved it becomes.
    Anyway, I've installed "auto-start" systems on other vehicles and they work MUCH better (stronger signal, longer range etc.) than the auto-ac prius setup. The main difference would be the operator would have to set the HVAC system to appropriate settings before shutting off car as the auto-start simply starts the car (brings on-line in the case of a hybrid) and doesn't change settings. Make sure the manufacturer supports the Prius before purchase as the installation is fairly involved.
  9. b100
    b100 Member
    145
    75
    Netherlands
    The solar package comes whit a AC button on the remote
  10. SB6
    SB6 Member
    324
    71
    Any answer on the original question? I was recently shopping around for an extra key fob, and saw some options with the AC button. Does my car have to have something added, or will just having the remote with AC button work? I bought my car used with just one key fob, no AC button. Lock/Unlock, and alarm buttons. I don't have a solar roof. 2010 Prius II
  11. JSB_99
    JSB_99 Member
    66
    48
    Houston
    It's part of the solar roof package so my assumption would be if you don't have that then you can't just get the fob and get it to work. It's not that great anyways as I have it. It only works if the battery is above a certain level and then it will only run for a couple of minutes.
