Remote Air Conditioning
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by markabele, Jun 13, 2013.
  1. 3PriusMike
    3,101
    2,421
    Silicon Valley
    There is no way I think that that the A/C draws as much current as the charger, even with 110v can supply.
    My inefficient refrigerator compressor only draws 200 watts.
    Here is a quick test for those with no OBD II scanner. With the car on and plenty of battery EV miles, turn everything off except the A/C on max. Watch how long it takes for the EV miles to click away. In my car I get about 14 miles per 2.7 kwh charge. Turning on the A/C lowers it to about 12.5 immediately. Therefore, each 0.1 miles represents 21.6 watt hours. Maybe it takes 3 or 5 minutes to use up 0.1 miles...ignore the first one (a partial) and time until the second one clicks off.
    Let's say it takes 3 minutes. In an hour it would be 20 of those...or 20/h * 21.6 watt-hours...or 432 watts.
    If the A/C took the entirety of the ~1350 watts the 110v charger supplies, then it would click off 0.1 miles 62 times an hour or in less than a minute. I think it takes longer than that.
    Anyway, there should somewhere be a spec on how many watts the A/C compressor consumes.
    IIRC I read that the Prius A/C had a cooling power of 3.4 kw. At a modest SEER of 10 that would mean 340 watts for the compressor. (Also need to add in the power for the fan).
    Mike
  2. markabele
    5,084
    1,782
    Nebraska
    If I remember correctly...
    I used to use the torque app on my old Gen3 (yet to get it going on the pip) and it would tell me anywhere from 0 to 1200 watts for the ac. It would very rarely be as high as 1200 though.
