Remote battery dies after 3 day
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by xerox6135, Jul 15, 2018.
  1. xerox6135
    xerox6135 Member
    170
    94
    michigan
    I have a 2013 Prius Persona has 100,000 miles on the clock. I have replaced the remote battery 2 times and it only last about 3 days before its dead. I also replaced the battery in the wifes remote hers works as it should. My question is this how these remotes go bad and you replace them . Any help would be appreciative
    52,674
    it is usually a button stuck down.
  3. xerox6135
    xerox6135 Member
    170
    94
    michigan
    I checked that they all seem to click when pushed down . I even took remote out of the case the swithes seem to click when pushed in and out.
  4. Grit
    Grit Senior Member
    6,577
    4,230
    Wilkes Land
    Check the button battery package expiration date. And if you bought a good pack at a good price from ebay, thats how it goes. When I cheap out like that, the button batteries don't last.
  5. bisco
    52,674
    i suppose the fob could be bad. try cleaning the buttons and circuit board. a new fob will be a few hundred bucks i think.
  6. xerox6135
    xerox6135 Member
    170
    94
    michigan
    I checked the expiration date 20/20 bought the Batteries at a local store but I suppose it's possible to get two bad ones. I will try one from a different place .
  7. bisco
    52,674
    if your wife's works, just try her battery.
    4est likes this.
  8. xerox6135
    xerox6135 Member
    170
    94
    michigan
    I did and in 3 days battery was dead .
  9. bisco
    52,674
    was it in hers for more than 3 days?
  10. xerox6135
    xerox6135 Member
    170
    94
    michigan
    Yes was in hers for about 2 weeks. I replaced her again and works fine after 3 weeks this has been going on for a little over 2 months
  11. bisco
    52,674
    not the battery then. there are some threads here on cleaning, but many fobs just never work again, unfortunately.
  12. xerox6135
    xerox6135 Member
    170
    94
    michigan
    Dealer confirms bad remote. Replace it under toyota extended warranty life is good
    Bay Stater, Mendel Leisk and bisco like this.
  13. bisco
    52,674
    wow, great deal. that's like 400 bucks!(y)
  14. Mendel Leisk
    42,165
    I wonder what they wholesale for... :cautious:
  15. bisco
    52,674
    4 cents...
  16. xerox6135
    xerox6135 Member
    170
    94
    michigan
    I would say if they have 10 dollars I would be surprised
    4est and bisco like this.
