Remote Battery getting exhausted
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by itengineer, Apr 7, 2015.
  1. itengineer
    itengineer Member
    86
    25
    Minneapolis
    I'm going to store the key in a RF shielded box when not in use and see if that makes a difference to battery life. Updates to follow.
  2. ericbecky
    ericbecky Hybrid Battery Hero
    4,451
    3,359
    Madison, Wisconsin
    The situation I experienced was that one fob was draining, but the second fob was not.
    Both stored in the same place.
    Coat pocket about 20 feet away, inside house.
    Phone was the same (Razr flip-phone) and stored 10 feet from coat. On desk between coat and car.
    No other new electronics in the home.
  3. mrbigh
    3,686
    699
    Long Island, NY
    Store the fobs in a steel tin can of any size/shape. That will isolate any RF.
    52,773
  5. mrbigh
    3,686
    699
    Long Island, NY
    but with a cover.......
  6. ericbecky
    4,451
    3,359
    Madison, Wisconsin
    Altoids tin.
  7. Bill the Engineer
    1,048
    2,278
    467
    At the beach in Delaware...
    I used to have a problem with other things in my pocket pressing on the key fob buttons and draining the battery. Then I came up with the solution of placing a store loyalty tag and rubber band over the buttons. Problem solved.
    Bill the Engineer
    gdanner likes this.
  8. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,801
    Undisclosed Location
    Interesting, if somewhat disturbing thread.
    It's been about 2 years, I've been thinking of changing the battery in my fob, but since this problem manifested after battery replacement, now I'm thinking I'll just wait until it get's visibly worse.
    But this is really interesting. Since in both cases, it seems nothing is changed in usage, or location, and the only parameter seems to be that the battery has been changed.
    Very interesting. I'll be watching this thread to see what eventually is determined. If any answer is ever found.
  9. ericbecky
    4,451
    3,359
    Madison, Wisconsin
    I have the old fob.
    As much as I'd like to do testing of it and find the cause, it'll probably just be tossed in my parts bin.
    Too many other projects.
  10. bisco
    52,773
    were you on the apollo 13 engineering team?:p
  11. Bill the Engineer
    1,048
    2,278
    467
    MacGyver got all his ideas from me!
    Bill the Inventor
  12. itengineer
    itengineer Member
    86
    25
    Minneapolis
    Update:
    In spite of turning off the bluetooth on the iPhone and storing the fob in a metal container when not in use, the fresh new battery exhausted in just a few days.:(
    So, maybe I do need a new fob?
  13. bisco
    52,773
    sure sounds like it. but wait, you said it's happening on both fobs. unlikely at best.
  14. AzWxGuy
    AzWxGuy Weather Guy
    1,078
    558
    Tucson, AZ
    2021 Prius
    Does anybody know anything about the specific radio frequencies that these things operate at? We are constantly bathed in RF energy from all sorts of sources. Could be something like that. The CR1632 battery from any and all manufacturers should be a lithium cell which has a characteristic power curve of providing nominal voltage (3 VDC) right up to exhaustion where it rapidly drops off. The only other thing I can think of would be a short in one (or more) of the momentary contact switches on the top of the printed circuit board contained within. Maybe a good dusting and/or cleaning with a non-conductive electronics cleaner might do something.
  15. bisco
    52,773
    it just wouldn't make sense for both fobs to do it at the same time after 3-4 years.
  16. wjtracy
    wjtracy Senior Member
    11,374
    3,609
    Northern VA (NoVA)
    Sounds like a short of some kind I recently had this on an iPhone due to lint Etc in the charging port. Note that the button battery has small gap that if bridged will short. perhaps try some thin tape over the gap to make sure the battery is not being shorted directly. Otherwise it could be some debris or water damage internally causing the problem. You can try to clean as best possible. I think I fixed the iPhone but only after I pulled the trigger on the upgrade
  17. ericbecky
    4,451
    3,359
    Madison, Wisconsin
    Can you clarify this a bit. I'm not sure what you mean by small gap?
  18. bisco
    52,773
    a short in both fobs at the same time?
  19. bisco
    52,773
    i'm wondering if the car could be depleting the fob battery while driving.
  20. itengineer
    itengineer Member
    86
    25
    Minneapolis
    That is another possibility.
    I should clarify that one of my fobs exhibited the battery depletion issue first which caused me to switch to the other fob which then started to exhibit the same issue. There might have been a period of weeks to months between the 2 events. Never used both fobs simultaneously.
    I might do the cleaning of the circuit board as the next step and will test as soon as I receive my fresh set of batteries from Amazon(luckily I'm Prime so should receive in 2 days)
    Also, will test the theory that the car is depleting the batteries while driving. I'll place the keyfob in a metal box while driving.
    Once I put in a fresh battery, the fob works great. All the buttons work perfectly
    #40 itengineer, Apr 13, 2015
