Remote Battery getting exhausted
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by itengineer, Apr 7, 2015.
  1. Easy Rider 2
    Easy Rider 2 Senior Member
    1,584
    258
    Ocala, FL
    Probably not a good test. The car will complain if it can't "hear" a FOB close by.
    52,597
    but it will keep running.
  3. wjtracy
    wjtracy Senior Member
    11,374
    3,609
    Northern VA (NoVA)
    Trying to think this thru, but you could keep key fob away from car or turn off SKS system to see if batt drain is just something happening to your Fob even when it is "OFF"
    The analogy to my iphone is I tried to turn it off to see if batt was draining when off. Only to find out I could not turn it off permanently, it just came back on later. This finally allowed me to Google the issue was short due to lint or malfunction in the charging port. Opps Gen3 I don't think SKS has off setting?
    #43 wjtracy, Apr 13, 2015
    52,597
    maybe in the menu.
  5. itengineer
    itengineer Member
    86
    25
    Minneapolis
    I will try that with one of the fobs. I'll put in a new battery and put it away in the basement for a few weeks to see if there is a parasitic drain.
    I read in some other threads that when the 12V Aux battery begins to weaken, the SKS system begins to behave strangely.
    wondering if I shouldn't just change the 12V Aux battery?
  6. ericbecky
    ericbecky Hybrid Battery Hero
    4,450
    3,355
    Madison, Wisconsin
    The drain I experienced was a parasitic drain, but just on one fob.
    The other fob didn't exhibit the drain.
  7. bisco
    52,597
    wouldn't hurt to test the 12 volt, not sure i'd just change it out without testing.
  8. wjtracy
    11,374
    3,609
    Northern VA (NoVA)
    I am just sayin anything conductive that bridges the black line in below pic will short out battery. If I am making a homemade button battery holder, sometimes I will place some electric tape over the gaps to prevent short.
  9. itengineer
    itengineer Member
    86
    25
    Minneapolis
    Update: One of my fobs just came to life.
    I thoroughly cleaned the circuit board and battery compartment with alcohol and cotton buds avoiding the RF transmitter. Put everything back and it worked and this was with an old battery.
    I'll put in fresh ones tomorrow in both fobs and give it a longer duration test.
    Former Member 68813 likes this.
  10. bisco
    52,597
    great, but it makes no sense, since you tested the battery out of the fob.
  11. Bill the Engineer
    1,048
    2,278
    467
    At the beach in Delaware...
    Conductive pocket lint. :rolleyes:
    Bill the Engineer
  12. ericbecky
    4,450
    3,355
    Madison, Wisconsin
    Ahh, yes CPL. I think that is a real thing... isn't ? lol
  13. Radiohound
    Radiohound Junior Member
    Gilroy, CA
    The Gen II operate at 315 Mhz
    Some decoding info here:
    Prius Key Fob Study
    gdanner likes this.
  14. AzWxGuy
    AzWxGuy Weather Guy
    1,077
    554
    Tucson, AZ
    2021 Prius
    Hmm, interesting. That is also the frequency that most garage door openers operate at. But it sounds like a good cleaning was all that it needed.
  15. Former Member 68813
    3,524
    983
    US
    thanks for the tip on the cleaning part. i have a smart key with shrinking battery life. the first battery lasted 4 years, second 9 months, and third is failing after 3 months already.
  16. Former Member 68813
    3,524
    983
    US
    update, the "old" battery was 3V. too low for it to work. New is over 3.3V. the inside of the fob was clean, but i wiped it with alcohol. i noticed that the new battery has instructions to "wipe" the cell before installation. i did that with alcohol too and tried to avoid touching it with fingers while putting it in. will report back how long it lasts this time.
  17. Former Member 68813
    3,524
    983
    US
    update 2: not even a month later, problems again. sometimes the fob is completely dead but works when i wiggle/twist the plastic body.
    next step: i'll check for dry/cracked solder. anything else to check for?
  18. Jim T
    Jim T Junior Member
    22
    New York State
    When I had problems with my fob the Toyota service rep said they often have to bend the contacts to put more tension on the battery edge. Did you check the voltage on the recently replaced battery? As noted in my earlier post I ended up getting a new fob since mine was consistently draining batteries quickly.
  19. Former Member 68813
    3,524
    983
    US
    it's in my post: the "old" battery was 3V.
    update 3:
    i couldn't find any dry joint, but it's difficult to see anything in those SMD. i bent the battery contacts slightly and greased them with dielectric grease. so far, dielectric grease fixed all kinds of bad connection issues for me. maybe it will work this time.
    i also practiced the mechanical key. the door closing action is fine, but opening is a bit hard and not smooth. i greased the blade but no help. i guess it's not meant to use often.
    #59 Former Member 68813, Oct 2, 2015
  20. AzWxGuy
    AzWxGuy Weather Guy
    1,077
    554
    Tucson, AZ
    2021 Prius
    I will agree that cold solder joints are difficult to detect. You have to get up close and personal. Would recommend a 2X/3X magnifying head visor. Radio Shack has a good one. Since you can't take the SMD out of the circuit easily, just use a small pick to flex the joint while carefully observing. The usual spot for a break will be between the solder bead and the printed circuit trace or sometimes a lead and the solder bead. If I can't find it this way and the problem persists, then I will carefully re-melt each junction with a 14W grounded soldering iron.
