Remote Distance
Discussion in 'Prime Technical Discussion' started by dave3057, Sep 22, 2017.
  1. dave3057
    dave3057 Member
    68
    37
    Baltimore, Maryland
    Anyone else getting really poor range using the key fob to lock their Prime? Like sometimes I need to be like 5 feet from the car to get it to lock. I’m not sure if it’s an interference issue, but I’ve had it in multiple places, and if I forget to hit my button when I’m walking away, I may as well walk back and hit the touch sensor I have to get so close.
    iPad ?
  2. dave3057
    dave3057 Member
    68
    37
    Baltimore, Maryland
    This was posted in the wrong section
    iPad ?
  3. hill
    9,015
    Battery?
  4. dave3057
    dave3057 Member
    68
    37
    Baltimore, Maryland
    Swapped out the battery. Just to check. It’s brand new. Only has 2k on it.
    iPad ?
  5. FuelMiser
    FuelMiser Senior Member
    1,349
    929
    Monument, CO
    If you post in the wrong section, simply click the "Report" button on your post and ask the moderator to move it to the correct forum...
    dave3057 likes this.
  6. hill
    9,015
    Just one fob? or is the range of both fobs similar?
  7. dave3057
    dave3057 Member
    68
    37
    Baltimore, Maryland
    its both, i think..actually i don't remember if i tried the other one..
  8. hill
    9,015
    You need to eliminate all the obvious stuff. That would be a good place to start.
  9. Ferrarilover
    Ferrarilover Active Member
    185
    168
    Manchester, UK
    Hold it to your head and you’ll get better range. I saw that on top gear.
    iPhone ?
    kithmo likes this.
  10. dave3057
    dave3057 Member
    68
    37
    Baltimore, Maryland
    I tried that. Looked like an idiot, and it still didn’t help.
    iPad ?
    kithmo and Ferrarilover like this.
  11. dave3057
    dave3057 Member
    68
    37
    Baltimore, Maryland
    Just did it. Thanks
    iPad ?
  12. kithmo
    kithmo Couch Potato
    2,404
    2,776
    47
    South Yorkshire, UK
    I think you have to hold your other arm up.
  13. mark27lim
    mark27lim Active Member
    108
    104
    singapore
    its under your chin that uses your skull as an antenna amplifier. it works for my gen4.
  14. Salamander_King
    Salamander_King Senior Member
    11,024
    8,977
    New England
    Weak battery? I know it is brand new, but maybe some bad batch of battery got into the fobs. Worth checking, I think.
  15. dave3057
    dave3057 Member
    68
    37
    Baltimore, Maryland
    I tried a new battery first. Didn’t change anything. I also just grabbed my other fob from Home, and it hasn’t changed.
    iPhone ?
  16. Salamander_King
    11,024
    8,977
    New England
    Strange. Does it happen any place you park, or one particlular place?
  17. Robyn Jackey
    Robyn Jackey Junior Member
    Massachusetts
    I am finding this situation too. Not always, but sometimes the range is very short, like I have to be within reach of the door for the remote to lock the car.
  18. dave3057
    dave3057 Member
    68
    37
    Baltimore, Maryland
    It happens pretty much everywhere. Although I don’t really go that many other places with it (besides work and Home). But whenever I do, it does the same thing.
    iPhone ?
  19. dave3057
    dave3057 Member
    68
    37
    Baltimore, Maryland
    So I just noticed that the remote issue seems to happen when it’s plugged in.
  20. goluchowski
    goluchowski New Member
    USA - western Massachusetts
    Mine also inconsistently has poor range, plugged in or not. It might work better from behind the car though but I haven’t tested well. Once it worked about 200 feet away through glass which was impressive.
