Remote Lock Key Entry FCC ID
Discussion in 'Generation 1 Prius Discussion' started by JDirtbikerR, Nov 13, 2013.
  1. Wisco
    Wisco Member
    116
    Well my girlfriend tried to program the fobs also, and she had the same result.
    The key is a master key, and the car works fine in all other respects. I'm going to double check that the lock actuators work on all the doors, but I don't have any other ideas..
    Turn off signatures in Tapatalk Tapatalk
  2. vaughnstark777
    190
    33
    Roy, WA
    2001 Prius
    I
    Since you allready hsve them cut you may have to break down and look for a locksmith that will take your master and the copies and do it with their equipment:(
    SCH-I605 ?
  3. Wisco
    Wisco Member
    116
    I'm not worried about keys, just the remote for the door locks. When I said "master key" I was referring to the key inserted into the ignition during the programming.
    I suppose a shop might have another way. It'd be great to have remotes, but I'm not sure it's worth paying the labor.
  4. vaughnstark777
    190
    33
    Roy, WA
    2001 Prius
    I
    Sorry, my bad.
    SCH-I605 ?
  5. Wisco
    Wisco Member
    116
    I appreciate the input. I'll post here if my googling and fiddling yield results.
