Remote start and charging?
Discussion in 'Prime Plug-in Charging' started by wrenwren8, Dec 27, 2017.
  1. Prodigyplace
    12,712
    11,848
    Central Virginia
    Report to the dealer that the remote starter does not perform as expected for your application. Perhaps they will give you a partial refund or remove for a complete refund.
    It's worth a try, at least. They need to know you are unhappy.
    bisco and Mendel Leisk like this.
  2. Salamander_King
    Salamander_King Senior Member
    11,024
    8,978
    New England
    Thanks for your update. That was exactly what we were predicting. While it is nice to be able to start engine remotely to warm up the cabin before getting in the car in morning, if one has to go out to the car to remove the charger cable, it defeat the purpose of having remote for someone who does overnight charging... like me. ;) Let us know how your car warms up with your remote starter. During this morning sub-zero weather commute, my Prime warmed up only up to 45F in 30 min of commute with engine on all the way. I have to wonder how well it heats up in 10 min while parked.
    #22 Salamander_King, Dec 29, 2017
  3. jungleland1972
    73
    65
    Chesapeake Beach, MD
    Mine does not heat up very well but every little bit helps. I just wish the hold time was shorter for the remote AC start (10 seconds seems like a bit much).
    52,847
    seems like the toyota software should have had a work around for the remote starter to start the engine, without allowing the car to be put into drive.
  5. Tideland Prius
    16,679
    For the remote? Isn't it 0.8 seconds?
  6. Prodigyplace
    12,712
    11,848
    Central Virginia
    It sounds like the Remote Start vendor should have had a a work around or not sold the product as being compatible with the Prius Prime.
    It is not Toyota's responsibility to customize their vehicles for third party products.
  7. bisco
    52,847
    whoops, i thought it was dealer installed, never mind.:oops:
  8. Salamander_King
    11,024
    8,978
    New England
    Yes, OP said it is dealer installed, but it is not Toyota product. Its compustar. See comment on #3.
    Prodigyplace likes this.
  9. bisco
    52,847
    thanks, i guess the dealer should know better. would have to see compustar's literature.
  10. CraigM
    CraigM Active Member
    208
    208
    Portland, Oregon
    I wonder if anyone has died (carbon monoxide) from remote gas engine starting in their attached garage?
  11. bisco
    52,847
    unlikely, the levels are extremely low.
  12. Prodigyplace
    12,712
    11,848
    Central Virginia
    I don't know but we had an Alaskan user here where the dealer had incorrectly installed the Engine Block Heater with the power cord through the active shutters. The user rerouted it after shutter errors. A while later, it caught fire and the source pointed toward the EBH power cable. I guess it may have been internally damaged.
    Dealers do not always make the best decisions.
  13. Tideland Prius
    16,679
    There were a few cases many years ago when SKS and push button start was new and people didn't shut down the car after they parked in the garage. This occurred in places where the garage was attached to the house.
    Not exactly the same as remote engine start but similar.
  14. CharlesH
    2,798
    1,166
    Roseville, CA
    My understanding is that that in all modern cars that have a gasoline engine (in the US, anyway), the CO emissions are very low, likely too low to kill someone. Part of those pesky emissions controls that the current administration finds so onerous.
    Toyo_Tom likes this.
  15. wrenwren8
    wrenwren8 New Member
    22
    Alden, NY
    It was free..thankfully :)
    I can't seem to figure out the AC start.. I press and hold the button and a red light flicks on for a second.... I see nothing going on with the car and no indication that it is doing anything? I have tried pressing and holding longer.. still nothing? How do you know if anything is going on with the car after pressing that AC button on the fob?
    #35 wrenwren8, Dec 30, 2017
  16. Prodigyplace
    12,712
    11,848
    Central Virginia
    ..then I guess you got your money's worth if it does no harm to the car long-term.
    For me, since it does not work as expected, I would likely want it removed, also for free.
  17. Salamander_King
    11,024
    8,978
    New England
    When you press remote A/C on your fob, the car will respond by locking all the doors, beep, and flash lights. If it is still connected to charger cable, then the blue charging lights on front dash will come on to indicate replenishing charging of the battery. You will hear some weeling noise from engine compartment which I think is from some fans and pump for heat pump. That's it. Engine will not come on. And as I have tested on mine, if it is below 14F ambient temperature, remote A/C will not do anything to warm up the cabin temp. Heat pump is not effective in heating at low temperature.
    #37 Salamander_King, Dec 30, 2017
  18. jungleland1972
    73
    65
    Same here, and if you want the heat/AC to kick on you remain holding it down for around 10 second and all of the blue lights (I think all but it could be just 3) come on.
  19. CharlesH
    2,798
    1,166
    Roseville, CA
    It takes some getting used to for folks new to the Prius, that pretty much nothing it does other than traveling significant distances requires that the gasoline engine start. The air conditioning, heating (for the most part), power steering, power brakes, even initial movement, are all electric. All the START button does is power up the various control systems, making it READY to go. This is different from conventional gasoline powered cars, where START means to start the gasoline engine.
    #39 CharlesH, Dec 30, 2017
  20. Tideland Prius
    16,679
    Isn't "all" and "3" the same? There are only 3 blue lights lol.
