Remote Start on Plug-in?
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by 13Plug, Oct 26, 2012.
  1. 13Plug
    13Plug Active Member
    581
    105
    2013 Prius Plug-in
    So I got good news today from the dealer, my new Plug-in Prius is on the water on it's way across the sea :)
    I live up here in cold Canada. OK, so it gets really cold in the winter (-30 C is common). Now I'm wondering how does the A/C button on the remote work? Is it literally just for remote air conditioning or can it also be used in freezing temperatures to remotely start the car to warm it up?
    Normally I don't warm up my car but when it's been sitting outside in -20C or colder I sometimes let it run a few minutes just to clear the windshield before I drive.
    If the A/C button doesn't work the heat also in the freezing cold, will this kit for the regular Prius work?? --> PriusChat Shop : 2010-2012 Toyota Prius OEM Remote Engine Start [PT398-47091] - $349.00
    Thx!
  2. benalexe
    benalexe Member
    198
    30
    Commack, New York
    The a/c button does not turn on the heat. Too bad. I wish it did too
  3. Electric Charge
    Electric Charge Active Member
    545
    133
    Syracuse, NY
    wow, that's a disappointment. Thought for sure it meant it was just turning on the automatic HVAC system, using the settings entered before turning the car off.
  4. CharlesH
    2,797
    1,165
    Roseville, CA
    The remote A/C system is designed to not cause the ICE to fire up. And with the PiP, heat comes from the ICE. So no heat.
  5. 13Plug
    581
    105
    2013 Prius Plug-in
    Well that sucks a little. I didn't have a remote starter on my 08 so it's not a big deal to me, the car is in my heated garage 350 nights a year. I'll just have to go out and start it manually on those few cold days/nights a year when it sits outside.
    I still wonder if that regular Prius remote start kit would work with the PHV?? hmmm...
  6. lensovet
    2,615
    496
    Burlington, NJ
    it does. but if the exterior temperature is below the set temperature, nothing happens.
  7. 13Plug
    581
    105
    2013 Prius Plug-in
    That's silly.
  8. lensovet
    2,615
    496
    Burlington, NJ
    Charles explained why that is. Heating in the PiP is provided by the ICE, because electric heating would be insanely inefficient.
  9. 13Plug
    581
    105
    2013 Prius Plug-in
    Yeah, I want my ICE to fire up when it's -20 or -30 though.
  10. Electric Charge
    545
    133
    Syracuse, NY
    I'm guessing no one has come up with an affordable add-on which will trigger the ICE when A/C is remotely turned on in cold weather? I'd hate to invest in a full blown remote starter, and carry another fob, when we are so close to having this system already.
  11. mxben
    mxben Junior Member
    29
    Quebec, Canada
    2013 Prius Plug-in
    When I ordered my pip in july I asked my dealer about a remote starter and he wasnt sure if it will be available now for the pip nor if the one for the regular prius will fit on the pip but I dont know why it wouldnt fit cause a pip is just a prius with a bigger battery and a charger. Also, he told that they usually install remote starters from an aftermarket brand instead of the one for toyota. They are cheaper and have a better range than the oem (80 feet only). At first, I was disappointed that the remote ac button wouldnt heat the car from the battery but when you think about it, it wouldnt make sense to use electricity to heat the car when heating from the ICE is done from wasted energy. I think that using the ICE first and saving the battery for ev miles is a smart choice from toyota but I dont expect too much ev miles in winter months since I am only 5 miles from work. What doesnt make sense to me is having to let the car idle for minutes before using it at the single purpose of generating heat. This car is supposed to be designed to use every drop of fuel as efficiently as possible. Toyota should sell an auxiliary electrical heater taking power from the grid while the car is plugged (from the charging cable or the engine block heater wire) to at least defrost the windshield.
    serlegar likes this.
  12. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    you'd need a pretty high wattage heater to heat the cabin. I have a 400 watt oil filled heater that plugs into 120 volts. tested it out overnight the other day when the outside temp. was 47 degrees. with the heater set at max, the inside temp was only 51 degrees ( expected 70 or higher)
  13. mrbigh
    3,686
    699
    Long Island, NY
    Slurpy.......
  14. terpsmandan
    terpsmandan Member
    144
    I am considering a block heater and yours should have heated seats.
  15. serlegar
    serlegar New Member
    Laval QC Canada
    I
    That is my feeling also, there sould be at least 1 x 110Volt plug inside the car where you can connect a heater with some kind of programmed timer. I believe the Leaf has this option of heating the car from the grid.
  16. fouaddba
    fouaddba New Member
    new to this forum, as recently bought Prius Plug-in, I wasn't able to start my car, using this A/C button on my key fob, am I doing something wrong ... or it's bad ... do advice, how to check/verify ... is it really working or not.
    And also my miles @full charge also reduced to just 9 miles, in just 5 months
  17. mrbigh
    3,686
    699
    Long Island, NY
    Your situation is being faced by many of all of us in winter time.......
  18. El Dobro
    El Dobro A Member
    7,095
    3,272
    The A/C compresser is electric, so it doesn't need the engine to run.
  19. lensovet
    2,615
    496
    Burlington, NJ
    A/C button doesn't start the car; it turns on climate control if the temperature setting when the car was turned off is below the outside temperature.
    the "range" issue is covered in the FAQ.
  20. George Wu
    George Wu Junior Member
    Granby, Quebec
    So this means in Canada, whenever we turn on the heat (for 5+ months), the internal combustion engine must fire up, thus defeat the purpose of having a plug-in?
