Remote Start PT398-47110 missing L79 in car
Discussion in 'Gen 3 Prius Accessories and Modifications' started by Tommy Johnsen, Apr 11, 2014.
  1. bisco
    52,804
    pack it up and mail it to him. what's the worst that can happen?
  2. Attila Beck
    Attila Beck Junior Member
    i did it of course. With Tommy Johnsen we are talking about two pin of the L7 connector what is missing from european car. So we dont the hole is present in the connector, but without pin.
  3. Tommy Johnsen
    Tommy Johnsen Junior Member
    33
    Norway
    Great news Attila!
    I can confirm that the Remote Start works! !!!
    Thank you for all your efforts and help.
    Without your information I would probably not have dared to try.
    Everything works as it should!
    I had to modify some pins to insert in the
    L7 connector for the Main Body ECU position 4 and 16.
    I found a side mirror camera for Land Cruiser 200
    at my workshop that had almost small enough pins..
    52,804
    congrats tommy! great help attila!(y)
    Tommy Johnsen likes this.
  5. Attila Beck
    I would like to share my experience from our private conversation about the problem:
    Finally i ordered Fortin Evo All bypass, and remote start system. (Im worry about i sold my factory remote too early)
    I asked Fortin Canada about this and get the following message:
    "Some vehicles, especially European vehicles, will not have any wires at the ECM for Tx and Rx. The 2014 Toyota Corolla in North America is the same thing. You have to add wires to the empty pins yourself..."
    After that i asked Fortin Russia. The answer:
    1. Yes, you can bypass your vehicle by EVO-ALL.
    2. You may need Flash-Link Updater in addition (if you want to use StandAlone mode = to start by OEM remote). In this case you must to set functions #15 (StandAlone) & #18 (Hybrid). Or simply order the module with these functions.
    3. I must confirm that your car does not have #4 & #16 pins with a probability of 99%. You must install them. The possible way is to found unused ones (with wires) in the connectors just inside your vehicle (somewhere behind the radio for example). I wonder if you can simply buy them. May be you can ask CAR Audio installers about pins (please find the picture enclosed)."
    I attached one pictures what i received from Fortin.
    I get a detailed pdf about the pin, but now i write from my mobile, and cant upload pdf, only photo...
    I hope, somebody can use our experience!
    And finally, Tommy: i would like to thank you for your support! The first idea was yours!!! (We have to look for similar wires like L79) that was the first when i started to use my brain :))
    If i catch my Fortin, i share my experience.
    Have a nice day for all! :)
  6. Tommy Johnsen
    33
    Norway
    My Remote Start Still works great!!!
    I've been using it for cooling before driving all summer. And now days gets the benefit of a warm and ice free car.
  7. John van.Remmen
    John van.Remmen New Member
    Nederland
    I'm strugglin with the same problem here. I need to reconnect the L7 connector.
    You say I need to reconnect to position 4 and 16.
    Now i have two cables which to connect (purple and green) which wire do i have to connect to which number?
    green 4 or green 16, purple 4 or purple 16?
    Thank you!! without I couldn't manege.
  8. Tommy Johnsen
    33
    Norway
    Sent fra min SM-G935F ?
  9. Tommy Johnsen
    33
    Norway
  10. John van.Remmen
    Nederland
    [QUOTE = "Tommy Johnsen, bericht: 2803318, lid: 121875"] Violette 4, Green 16. [ATTACH = full] 160474 [/ ATTACH]
    Verzonden door min. SM-G935F? [/ QUOTE]
    Thank you very much! I will built it Saturday. I will let you know .
  11. John van.Remmen
    Nederland
    Good evening, i tried to make it work on Saturday but i didnt succeed totally. The handshake worked but the last step in which the indicators have to blink two times after closing the hood did not work. The indicators dont blink at all. I am gonna try and find a solution to make it work.
  12. MagnusAG99
    MagnusAG99 Senior Member
    673
    521
    Norway
    Eyy, another norwegian prius owner lol, rare find.
