Remote start with fob (no app on phone needed)
Discussion in 'Gen 5 Prius Main Forum' started by 2023p, Apr 30, 2023.
Tags:
  1. KMO
    KMO Senior Member
    2,031
    751
    Finland
    2023 Prius Prime
    You're misremembering the 2nd generation. It had no text display on the main dash, and the multimedia screen didn't turn itself on.
  2. I Throw 99
    I Throw 99 Junior Member
    28
    2023 Prius
    XLE AWD-e
    I just tried this with my 5th generation, and it worked perfectly. Awesome.
    daisy555 likes this.
  3. Alan Nomoto
    Alan Nomoto Junior Member
    Seattle
    2023 Prius
    My experience with the fob is a really short range of like 20 feet. Cuts the utility of it… Used to start my Cadillac from the living room. Can’t unlock it until I’m a car length away.
  4. CruisnGrrl
    CruisnGrrl Active Member
    151
    128
    Ontario, Canada
    2023 Prius Prime
    XSE Premium
    if you hold the key fob to your head you can increase the signal range by using your body as an antenna.
  5. Numtini
    Numtini Member
    91
    94
    Cape Schrod
    2023 Prius Prime
    XSE
    Has anyone noticed a difference with fob-starting a 23/24 Prime plugged in vs unplugged? I am looking at the car, and I can see the lights flashing multiple times after holding on the third press, which seems to be the sign that you've done it right. Unplugged, it starts. Plugged in, it doesn't.
  6. Hammersmith
    Hammersmith Senior Member
    2,499
    2,562
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    Toyota PHEV's don't allow remote start while plugged in. To pre-warm/cool a plugged in PHEV, you need to use the Toyota app(and have an active Remote Connect subscription).
    mva and Numtini like this.
  7. priusdriver223
    84
    32
    Lala Land
    2023 Prius
    XLE AWD-e
    Hey there, I'm late but you have NO IDEA how much this means to me, thank you for letting me see the world with colors now! Cheers!
  8. Juju2
    Juju2 Junior Member
    Bozrah
    I have a case open with Toyota about the remote starting debacle on my 5th gen prime. I was told by the dealer that in order to remote starting the car I NEEDED the subscription which is false. I was able to remote start the car using the fob multiple times but it was hit or miss (more miss then anything) . I was on the phone for a painful hour explaining to Toyota on how you are able to remote start the car using the fob and finally it was acknowledged that my 23 Prime screen needs a firmware upgrade due to Fob to screen (apparently the screen in the car is the main brain of the vehicle) communication issues. I am bringing it on Wednesday to the dealer (ugh) under a warranty claim and will update everyone on what was found.
  9. PhoS
    PhoS Active Member
    258
    210
    Nowhere
    2023 Prius
    Limited AWD-e
    I don't have any subscriptions and my remote start works. The fob is just very flakey with poor range. If I walk up and watch the lights blink it starts every time.
  10. Juju2
    Juju2 Junior Member
    Bozrah
    So just an update on this the dealer told me even after the firmware upgrade that I still needed the subscription and Toyota is cracking down on people without a subscription slowly deactivating the key fob feature forcing you into the subscription. Needless to say my remote start is way too flaky works sometimes with the subscription only. Any other PP owners on here that can help out? I saw a few messages that my car needed to be at least 30 % charged in order to remote start……seems awfully silly to me
  11. Paul Gregory
    Paul Gregory Senior Member
    2,340
    614
    Alberta
    2024 Prius Prime
    XSE
    Mine starts with 3 key presses on the button.
    Maybe a change for 2024, I do not know.
  12. Juju2
    Juju2 Junior Member
    Bozrah
    Do you have the subscription to the Toyota app or just key fob? Is your PP always charged when you remote start?
