Remove cargo shade
Discussion in 'Prius v Main Forum' started by coach4docs, Dec 25, 2011.
  1. coach4docs
    coach4docs Junior Member
    Chicago
    I am unable to remove the cargo shade from the new v. The owner manual was no help. Please share the secret. Thanks
  2. dustoff003
    1,371
    335
    Waianae, HI (Oahu)
    Are you speaking of the tonneau cover over the cargo area? In the Gen. III Prius you just lift each end out of the u shaped channel it is installed in. I don't know how the Prius v is it more than likely is the same or the end may be spring loaded and you need to push the end in and then lift it out of it's mounting. Good luck.
  3. coach4docs
    Chicago
    Yes, the v configuration is different.there isn't the u brackets. However, thanks for the reply.
  4. dustoff003
    1,371
    335
    Waianae, HI (Oahu)
    Try the other way I mentioned it is another quite common way of affixing tonneau covers.
  5. Cactus Hybrid
    Cactus Hybrid Member
    129
    46
    Paradise Valley, Arizona
    The end caps are spring loaded. Just grab the left plastic end, retract and pull off.
  6. coach4docs
    Chicago
    Heading to the dealer. The inner collar of the end caps is extending out of the opening. Thus...unable to clear even when retracting.
  7. jcgee88
    jcgee88 Member
    181
    23
    Maryland Heights, MO
    I have a one week old Prius v, and I was having the problem
    of the tonneau cover end tabs not sliding easily into the
    U-shaped groove to lock. I got the problem solved today at
    my dealer. I should mention that my particular problem was
    precipatated by the cargo net, which was a dealer-added
    option in my case (which means this might not be a problem
    if the cargo net is factory installed).
    First, the end caps on my tonneau cover are not spring
    loaded, so I don't see how the advice offered above would
    work.
    Second, my problem was that the heads of the bolts were
    extending too far out, which meant that the tabs on the
    tonneau cover were being blocked by the bolts. I could
    wiggle the ends enough to eventually secure the tonneau
    cover in its extended position, but it would take 2-3 minutes
    to do that. The bolts secure a part that looks like a
    combination of a washer and hook to the inside of the
    U-shaped groove.
    Here are the two things the technician discovered that
    were the root cause:
    1. The bolts had not been tightened down sufficiently,
    thus causing the inpingement. There gave about a
    1/4" play for the underlying washer/hook.
    2. The reason for the insufficient torquing of the bolt is
    that the washer/hook part is just slightly too big to
    fit all the way into the conically-shaped screw hole.
    The technician at first tried to torque down the bolts,
    but they would not torque down even though we could
    see that they were not tight.
    The solution was that the technician went into their
    shop, machined the washer to a smaller diameter, painted
    the machined surface to avoid future rust, and then
    re-installed the bolt and washer/hook. The tonneau
    cover tabs now easily clear the bolt heads.
    He said he will submit a problem report to Toyota on
    this problem.
    I'm glad, because now my wife will stop complaining
    about that problem!
  8. rjparker
    rjparker Tu Humilde Sirviente
    11,062
    6,933
    Texas Hill Country
    To remove the cover completely the ends are spring loaded, plus you have to rotate up towards the small side window. Then you can store the cover below the fold up floor in a special slot.
  9. dustoff003
    1,371
    335
    Waianae, HI (Oahu)
    Try looking on page 328.
    You are correct.
    See post #2.
    Exactly!
    ?, What did the dealer say or do?
    Once again, Brilliant.
    I did not want to sound like an idiot third gen. owner poking his nose in the v forum, so last night while at the dealership went to the v in the showroom and experimented with the luggage cover. It was stowed under the floor I removed it from storage and installed it then removed it and stowed it again.
    The spring loaded ends fit in the square shaped recesses on the sides of the car. Both ends are spring loaded pick one or both push inwards and then figure which way you then need to angle the cover to remove/install.
    From Prius v Owner’s Manual Page 328. (Luggage Cover)
    Installing the luggage cover
    Set the holder of one side into the installation position, and then install both holders from below with the cover in its contracted state.
    Reverse the procedure to remove.
    They may not write the best operators manuals but the associated picture should be good enough to figure out the process. Maybe the instructions get messed up in translation?
  10. tanasit
    tanasit Member
    399
    60
    Philadelphia
    I got my V a few days ago and today went for a big shopping day, then the mentioned cover can't be removed!! I managed to carry all the stuffs back home. Turned on my computer, then search for the Cargo tonneau Cover and saw a clip on how to install. Next I added the word how to remove and Google got me here and the problem solved..
    Great forum and great members..
    Thanks a bunch guys
