Remove cylinder head sub assembly
Discussion in 'Gen 3 Prius Technical Discussion' started by RyanFlorida, Apr 20, 2018.
  1. RyanFlorida
    RyanFlorida Member
    36
    70
    Clermont, FL
    I am working on replacing the head gasket in my 2010 Prius 2ZR engine. I am down to the Cylider Head Sub Assembly but cannot get it off! Has anyone done this before, can anyone give me any tips? I removed all of the head bolts, engine mount, timing cover bolts, and anything else I could find that is near the head. I can get a screwdriver gently under one corner and raise it about 1/4 inch and cannot get it to move past that. I removed the nuts from the exhaust manifold but could not get the entire assembly off, when I move the head assembly it is moving freely from the exhaust manifold. Pic is from before I removed the head bolts.
    m.wynn, farmecologist and tpenny67 like this.
    52,819
    are you using the service manual?
    Raytheeagle likes this.
  3. GrGramps
    GrGramps Active Member
    294
    176
    Western North Carolina
    Never worked on one of these engines, but I wonder if your problem is related to the timing chain and camshaft sprocket??
  4. RyanFlorida
    RyanFlorida Member
    36
    70
    Clermont, FL
    bisco, I do have the manual, however I could not get the exhaust manifold off. There are two bolts holding it to the cat which I cannot budge out of place. I was able to remove all nuts from the rear exhaust port on the head. Pic below shows nuts on exhaust port, the nuts I can get off, the posts they screw on to are removable but I can't get those off either. 20180420_162925.jpg
    GrGramps, timing chain and sprockets are already removed, that was an adventure in itself!
    Must set chain to top dead center, orange links to those marks you see in the pic, then below the camshaft notch will line up to the 0 mark. Took about 30 minutes to get it in perfect placement, had to spin the cam shaft at least 30 revolutions to get the chain perfect.
    Raytheeagle and bisco like this.
  5. bisco
    52,819
    check @danlatu 's threads, not sure if he details it or not.
  6. Mendel Leisk
    42,317
    @danlatu maybe will have ideas. As we have invoked his name, when he comes online hopefully will notice this, have ideas.
    danlatu likes this.
  7. tpenny67
    tpenny67 Active Member
    464
    403
    Massachusetts, USA
    Thanks for posting the pics! It's the first shot I've seen under the valve cover of the gen3
  8. IMkenNY
    IMkenNY Im just being nosy
    477
    303
    Tropical Buffalo NY
    Four Touring
    I would think complete removal of the timing chain cover would be the norm.
    On other four cylinder engines I have had good luck leaving the exhaust manifold attached to the head and i have disconnected the exhaust at the flex connection but I cant speak for this 3er generation Prius.
    #8 IMkenNY, Apr 21, 2018
    mjoo likes this.
  9. Raytheeagle
    Raytheeagle Senior Member
    11,267
    15,526
    Bay Area, California
    2019 Prius Prime
    If attempting this work while the block is in the Prius, @leeb18c muggt had some advice:).
    That’s how he did his head gasket replacement ;).
    Good luck with your project and keep us posted (y).
  10. RyanFlorida
    RyanFlorida Member
    36
    70
    Clermont, FL
    I think that's the best advice, just remove the timing cover. After further inspection I believe there are two bolts that hold on the front timing guide, one in the lower block and one in the header assembly which the part I still cannot remove.
    I have been trying to find how to remove the camshaft pulley, anyone know how to do that? I should be able to get the timing cover off tomorrow but that camshaft pulley is still in the way :rolleyes:
  11. danlatu
    danlatu Senior Member
    533
    1,367
    maryland
    You can use the two bolts that hold the ac unit to remove the pulley. Use a pulley removal tool or bearing removal tool. I would remove all the head studs and leave the manifold alone, you have to pull the timing chain cover, engine mount, timing chain guides, This engine sucks to work on.
  12. RyanFlorida
    RyanFlorida Member
    36
    70
    Clermont, FL
    Awesome, thanks for that. So how do I get the crankshaft bolt out? Is it reverse thread?
  13. farmecologist
    farmecologist Senior Member
    1,960
    1,801
    Southern MN
    Wow good stuff. (y) You are way, way more adventuresome than I am! Bravo sir!
  14. RyanFlorida
    RyanFlorida Member
    36
    70
    Clermont, FL
    Got the head out! Thanks for all the tips!
    I'll post more pics and a write up once it's all back together and working!
    Hoping to make a timelapse video when putting it back together
  15. RyanFlorida
    RyanFlorida Member
    36
    70
    Clermont, FL
    Bunch of pics:
    1. Top of pistons and exhaust manifold
    2. Timing chain at front of pic, left side of vehicle
    3. Very bad build up on piston 2, I believe its number 2, second from the right
    4. All bad carbon build up on piston heads
    5. Intake valves ok, exhaust valves have a lot of buildup probably from sucking coolant
    6. All clean! New valve seals. I removed all of the valves and cleaned them up
    7. Close up, so clean, so nice
  16. RyanFlorida
    RyanFlorida Member
    36
    70
    Clermont, FL
    I was able to remove the crankshaft bolt by tightening the removed ac mount bolts into the crankshaft pulley and using a breaker on the crankshaft bolt. Bolt is NOT reverse thread. Lefty loosy! Doing this put a few scrapes into the block. To me, they're scars, battle wounds, it adds character.
    m.wynn and danlatu like this.
  17. douglasjre
    douglasjre Senior Member
    2,250
    751
    Null, NL
    I'm just south of you in Lakeland doing the same job now. It looks like your leak was into cylinder 2. Mine was into cylinder 1. IMG_20180417_182604.jpg IMG_20180417_182549.jpg
  18. Gypsy62
    Gypsy62 Junior Member
    38
    North America
    Newbie '05 owner (Pro soob mechanic).
    Suggestion:
    Anytime I pull a head on any vehicle, I use "Aircraft Aluminum Spray Cleaner" to remove any carbon build-up on the tops of pistons. Presumably, you had the head tank-cleaned (and maybe magnafluxed, valve-seats spun, etc) at a machine shop before installing the fresh valve stem seals (& other fresh valvetrain components?).
    I refuse to mount a freshened head & gasket above ugly dirty pistons. 5 minutes with spray cleaner and they look new. Performance benefits as well. Effective but toxic stuff; use a respirator & heavy rubber gloves while ragging clean.
    #18 Gypsy62, Apr 22, 2018
  19. RyanFlorida
    RyanFlorida Member
    36
    70
    Clermont, FL
    We have some nice weather to be doing this right now! I've been doing mine in the driveway.
    How many miles on yours? Did you clean those piston heads, or was that how they were? Mine had a lot of bad build up.
    Gypsy62, I cleaned my piston heads with carb cleaner, they came pretty clean. I'm sure aircraft aluminum cleaner would shine them up nicely. If I was doing this job on a sports car or a larger engine I would get them the cleanest I could, but this is a cheap car, I'm not going to put too much into this.
  20. douglasjre
    2,250
    751
    Null, NL
    No cleaning on my part. I was a mechanic years ago and never did clean anything. We had cleaning people for that.
    Mine is in the garage. 210k miles and it's one of two Prius I own. I convinced 7 of my friends to get Prius'. We have gotten quite good at servicing them and this is the first head gasket job among our collective Prii. Send you a picture with my number. Buzz me if you run into any roadblocks. We might need to share ideas.
    Doug
    farmecologist and m.wynn like this.
