Remove cylinder head sub assembly
Discussion in 'Gen 3 Prius Technical Discussion' started by RyanFlorida, Apr 20, 2018.
  1. Rc.driver
    Rc.driver New Member
    San jose
    Doing a head gasket currently. Should all the pistons be even before reinstalling the head or Should piston 1 and 4 be up well 2 and 3 be down?
  2. ChapmanF
    19,001
    Don't think it matters much, until you're ready to install the timing chain.
    Rc.driver likes this.
  3. Mendel Leisk
    42,317
    If all the marks on the timing chain match up with corresponding marks on cam and crank shafts, then everything is where it should be?
  4. ChapmanF
    19,001
    Right. To get to that point, you'll want to follow the steps in the manual carefully, get the crank to the right position without having pistons cross TDC in cylinders where the valves are down.
  5. Mendel Leisk
    42,317
    To avoid collisions. Go dead slow when rotating anything.
