Remove Hub Caps
Discussion in 'Gen 5 Prius Main Forum' started by Prime User, Oct 23, 2025.
  1. Prime User
    Prime User New Member
    2023 Prius Prime
    SE
    Hello Fellow Prius Prime owners (2023+)
    I live up north and the white stuff is expected soon. So, I need to switch to winter tires soon.
    Anyone know how to remove the hubcaps to access the lug nuts?
    I tried a few things and it refuses to budge, I am afraid I am gonna crack and destroy the plastic caps.
    Please help with any instructions or videos.
    Thanks in advance
  2. Brian1954
    Brian1954 Senior Member
    2,677
    1,071
    South Central PA, USA
    The owners manual is a good thing to read. It should have the information that you are looking for.
    #2 Brian1954, Oct 24, 2025
  3. Mendel Leisk
    42,343
    17" or 19" rims? Assuming 17" rims, with the full wheel covers:
    There's a section in the Owner's Manual, for vehicles with spare tires, that describes removing the wheel:
    Just my 2 cents: if you can fit hands through the opening, you might try yanking there, and work your way around. The only ones I've done lately are Tesla model 3, and they're tough to break loose.
    #3 Mendel Leisk, Oct 24, 2025
    VelvetFoot likes this.
  4. Winston Smith
    Winston Smith Active Member
    473
    339
    OH
    2024 Prius
    LE AWD-e
    I got a good grip on two of the five spokes and pulled quickly with a lot of force. Yes, they feel fragile. None of mine broke..
    reservoirblue and Mendel Leisk like this.
  5. reservoirblue
    reservoirblue Member
    96
    76
    Woodacre, CA
    2024 Prius Prime
    SE
    If you break them, I'll send you mine. I doubt I'll ever put them on again.
  6. Winston Smith
    473
    339
    OH
    2024 Prius
    LE AWD-e
    I'll never break them because I'll not put them back on unless I am selling the car.
    I prefer the uncovered wheels, and am not interested in putting them back just so an urban entrepreneur can pop them off.
    reservoirblue likes this.
  7. Prime User
    2023 Prius Prime
    SE
    Thanks everyone
    I tried poking with the wrench but no joy
    Eventually I just yanked them out :) took a bit of force but thankfully nothing cracked
    I agree it looks a lot better without the hubcaps. However, I feel since they cover the lug nuts its a good thing as they will prevent water, salt and snow from getting inside and rusting the lug nuts
    We shall see....
    Cheers!
    Anish
  8. Mendel Leisk
    42,343
    The centre, hub opening is also a rust concern. Centre caps are best for preventing that. The caps for 19” rims are likely/hopefully compatible. If you’re just putting the full wheel covers on, brushing a little anti-seize on the hub helps allay rust.
    GcinFl likes this.
  9. VelvetFoot
    VelvetFoot Senior Member
    1,408
    545
    New York State
    2026 Prius
    On a somewhat facetious note, would you prefer the silver-colored anti seize, or the gold colored? I think I'd go for the gold. :)
    edit: someone recently measured and purchased some off Amazon, as I recall.
    edit2: #37 , eBay
    #9 VelvetFoot, Oct 28, 2025
  10. Mendel Leisk
    42,343
    I’ve got the silver, Permatex brand. Use it for wheel hubs, sparingly, and brake pad, shim and caliper contact points. Have a new tub on hand, but still digging out remnants from the old one, likely bought that in the eighties lol.
    the gold looks cool though, have seen that when dealership did brake service. Not sure of the differences.
  11. hill
    9,037
    There are ½ a dozen YouTube videos that are Prius specific.
  12. B0v1n
    B0v1n New Member
    Québec
    2026 Prius Plug-in
    SE
    new here this is probably a little late but I bought oem toyota center caps part 42603-0E070. They fit perfect and solid clip engagement. Here are some pics. I paid 65 Canadian sheckles give or take from the local dealership including taxes.
  13. Mendel Leisk
    42,343
    That'll definetely keep the hubs from rusting up. If-and-when you've got the wheels off, a thin coat of anti-seize on the hubs, and the face that contacts the back of rim, will preserve the area further and prevent rims rust-gluing on.
    Looks like the plastic wheel covers scuffed the rim some? If it's light I'd rub some polish on, and/or touch up paint, if you can find a near-match.
