Remove overhead map light assembly?
Discussion in 'Prius v Audio and Electronics' started by Drewintoledo, Sep 26, 2016.
  1. Drewintoledo
    Drewintoledo Junior Member
    49
    Ohio
    2015 Prius v wagon
    2015 Prius v Three, not III.
    Does anyone have a clue how to remove the overhead map light assembly? I'd like to drop it to get tap some wires to power a dashcam.
    I don't see screws behind the light. I don't see screws in the sunglasses holder.
    I do have a small rectangular plastic filler between the lights that might be hiding a screw, but all attempts to pop out said square results in marring the plastic around it.
    Help?
  2. rjparker
    rjparker Tu Humilde Sirviente
    11,003
    6,894
    Texas Hill Country
    The attached shows how on page 8 and 9. Probably the same on the 2015 but you can access Toyota docs for a fee on their TIS system. Includes photos from Kenneth Fuller.
  3. Drewintoledo
    49
    Ohio
    2015 Prius v wagon
    Thank you so much! I had the bezel out within 10 minutes of seeing your reply.
