Remove Paint spray from windshields and body
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by IR.AK.EB, Aug 4, 2017.
  1. IR.AK.EB
    IR.AK.EB Junior Member
    29
    Iran
    Hi friends
    I faced with strange situation.
    I noticed one week ago that all of windshields and most of body is being filled with paint spray and really i don't remember when it's happened!
    Is there any non destructive solution for removing powdred paint from windshields and body or not?
    The carwash staffs could not remove them and unfortunately ,their work added more scratchs to windshieds,body and rear plastics trim
    Thank you
    Akbar
    52,927
    i would seek the advice of a good body shoppe.
    Mendel Leisk and IR.AK.EB like this.
  3. IR.AK.EB
    29
    Iran
  4. kithmo
    kithmo Couch Potato
    2,404
    2,776
    47
    South Yorkshire, UK
    Using chemicals: depends what type of paint the overspray is, if it's not a car paint like cellulose or 2-pack, then White spirits or turpentine might remove it without harming the car paint, but try it on a small out of sight area first.
    T-Cut should remove overspray, but it's a lot of work and you must then polish and wax the car after t-cutting (more work).
    IR.AK.EB likes this.
  5. Mendel Leisk
    42,386
    You were maybe parked near some paint sprayers?
  6. IR.AK.EB
    29
    Iran
    Hi
    Thanks my friend.
    It's too hard for removing and unfortunately it caused a lot of scratch on windshields.
    It may according to ur advice,use some chemical luquid or wax for remove them.
    I try take some photo.
    Thanks again
    Akbar
  7. IR.AK.EB
    29
    Iran
    Hi Mendel,
    Really i'm not sure.
    I always park my car in my company parking or my home.
    I'm so badluck about having new car and abou 3 cars that i had before , i faced with some srange situations
  8. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    I'm no expert on this, but I'd have thought a single sided razor blade would suffice and should not cut into or scratch glass. Would not have normally suggested this except there seems no better solution that would not risk damage to the car's paintwork.
  9. IR.AK.EB
    29
    Iran
    Hi
    Thanks for ur advice.
    The paint spots are too small and hard to remove. I checked it before but it remained somw scratch.
  10. kithmo
    kithmo Couch Potato
    2,404
    2,776
    47
    South Yorkshire, UK
    Are you sure it's paint, it sounds like it could be concrete or cement, if so this is one method of removal:
    Mix 50/50 water with white vinegar, and using a spray bottle, spray that mixture on those spots and let them "soak." Then rinse with water and repeat as necessary. If the mix of 50/50 water/vinegar mix does not work, use the distilled vinegar full strength on the concrete spots.
    There are also concrete remover sprays you can buy, for glass mainly, but some are paintwork safe too.
    Check this one out:
    SPEEDY CLEAN Concrete & Mortar Dissolver – Cleaner 22oz – A Cleaning Product
    IR.AK.EB and RCO like this.
  11. IR.AK.EB
    29
    Iran
    Hi my friend.
    I will do and inform result.
  12. priusgto
    priusgto Active Member
    194
    231
    Northern Arizona
    Sorry I'm late to the thread but if you haven't had any luck removing the spots yet I'd suggest you do what is recommended for overspray. Go to a local auto paint supply store, if they have one by you, and ask for some medium overspray clay and lubricant. Wash and dry the car thoroughly first then spray the lubricant liberally in the area you need to do and rub the clay over the panel. This will not only remove paint overspray but also all the tiny contaminates and make the paint smooth as glass. The only issue with clay is that if you drop it on the ground it's done as it will pick up dirt which will scratch the paint if used again. I buy a bar then break it into several smaller pieces and store them in ziplock bags. If you're careful, a bar will last for several complete detail jobs.
    kithmo and RCO like this.
