Remove plug before driving?
Discussion in 'Prime Plug-in Charging' started by ericr, Jan 25, 2017.
  1. ericr
    ericr New Member
    Missouri
    Weird question, does the car stop you from putting it into drive if you are still plugged into the charger? Is there any mechanism that prevents you from doing this or does it just simply warn you via a message that it is plugged in and to not drive away.
    martydallas, fnostro and mr88cet like this.
  2. mr88cet
    mr88cet Senior Member
    2,313
    1,335
    Austin, TX
    Oooo... good question! I'll add "or shifting into reverse." Looking forward to hearing the answers.
  3. Optimus PRIME
    Optimus PRIME Active Member
    180
    141
    SF Bay Area
    Yes, you will NOT be able to start the car if the charging cable is connected to the car.
    fnostro and Bluegrassman like this.
  4. Lee Jay
    Lee Jay Senior Member
    5,850
    4,036
    Westminster, Colorado
    I think you can get a response from the power button:
    ■While charging
    When the power switch is turned to ON mode and the energy monitor displays,
    the charging connector is displayed on the energy monitor and the flow
    of electricity during charging is displayed (→P. 208). Also, when the charging
    connector is locked, is displayed.*
    *: Vehicles with smart lid & connector locking system only
    However:
    When the charging cable is connected to the vehicle
    Do not operate the shift lever.
    In the unlikely event that the charging cable has been damaged, the shift
    position may change from P to another position and the vehicle could move,
    possibly leading to an accident.
    What this tells me is that the car won't go into ready mode or shift out of park when you have a *working* cable connected.
  5. Optimus PRIME
    180
    141
    SF Bay Area
    I am pretty sure I tried moving the car while charging. It will not let me. The last part about possible damaged cable confirms this. If the cable is damaged and not working properly, then it is possible to move the car. But if the cable is working, you should not be able to move it.
    Lee Jay likes this.
  6. ericr
    ericr New Member
    Missouri
    Thanks!
    Thanks
  7. ericr
    ericr New Member
    Missouri
    Thanks!
  8. ruby
    ruby Member
    130
    78
    This morning I opened the car door to put some things in before unplugging and saw a big message on the display that said that the charging port door was open. I didn't try to start the car or drive.
    priuscatprimeguy likes this.
  9. huskers
    huskers Senior Member
    2,550
    2,489
    Nebraska
    This car will not allow you to make a mistake. Does it do dishes?
  10. Trollbait
    12,832
    The car is likely using the communication signal from the EVSE to see if a plug is actually in place. I guess it would be possible for that smaller gauge line to break within the cord without visible exterior damage.
  11. bisco
    52,886
    if it allowed you to drive off with the cable connected, i'd be on my tenth cable by now. too bad the gas pump hose isn't similar.:eek:
  12. Trollbait
    12,832
    Well, you shouldn't be leaving a gas pump unattended while filling it.
  13. giora
    giora Senior Member
    1,966
    730
    Herzliya, Israel. Car: Euro version GLI
    2013 Prius Plug-in
    It's not the com pilot from the EVSE but rather the Proximity Pilot between the connector (plug) and the car inlet. Signal from the EVSE is no good as it can be in shut-off status.
    The car charger management can distinguish by the Proximity Pilot between the three: properly connected plug, latch lever pressed and plug disconnected. This is part of the SAE J1772 protocol.
    #13 giora, Jan 25, 2017
  14. kevin54
    kevin54 Member
    57
    65
    New Hope, PA
    While charging my car I turned my car on to try and set a few things on my dash. I started like I do normally but the steering wheel is disabled and the car is not drivable (not that I tried but I noticed the steering wheel was disabled which prompted me to try the shifter). Can't do it!
  15. Dmitriy Sokol
    Dmitriy Sokol Active Member
    112
    108
    Annapolis, MD
    You can use the Accessory mode, but you will not be able to put in READY to drive while plugged in.
    ericr likes this.
  16. ptf
    ptf Junior Member
    Birmingh
    It doesn't do the dishes, but it will parallel park the car for you. Didn't know that before I bought mine, & it was a little freaky the first time I tried it.
  17. mr88cet
    2,313
    1,335
    Austin, TX
    And back-in park as well. Also help you get out of a parallel parking place, although I don't see much challenge there.
    Anybody know if it will back-in park other than between two cars (i.e., between a car and an empty space, or between two empty spaces)?
    I also wonder if it'll work with Austin's wacky "back in angled parking":
    I got a ticket once for, never having heard of this kind of parking, nosing into it from the other side of the road.
    iPhone ? Pro
    My first EV likes this.
  18. ruby
    ruby Member
    130
    78
    Nope. I tried that when I first got mine. It's looking at bumper height to find something to park in between. It won't park between two empty spaces.
    mr88cet likes this.
  19. mr88cet
    2,313
    1,335
    Austin, TX
    Thanks. I recall them saying that it doesn't help park next to a wall either. (That was in the "fine print" of one of Toyota's videos.)
    iPhone ? Pro
  20. Mendel Leisk
    42,368
    And the block heater... :oops:
