Remove plug before driving?
Discussion in 'Prime Plug-in Charging' started by ericr, Jan 25, 2017.
  1. ruby
    ruby Member
    130
    78
    I had my first automatic parking "fail" the other day. I was having the car perform back-in parking, and it was too close to the car on my side (I think about 6 inches), so I hit the brake. It was closer than I've ever seen it get during the maneuver. I'm thinking maybe the sensors had rain spots on them or something. Haven't had the opportunity to try it since then, but I'm sure I will.
  2. Since2002
    Since2002 Senior Lurker
    936
    1,098
    Duluth, GA
    Too bad it can't read the lines of the parking spot like it does with lane keep assist. That way it wouldn't require the presence of other cars, or be dependent on how well they lined up in their spot. If one of the other cars was close to the line or slightly over, it could give you a warning, and if you decided to proceed it would then adjust off-center to keep enough clearance from the offending vehicle. We'll probably see something like that in the future, in the meantime it will just require some experience to determine when to use it, and when you will either need to park it yourself or just keep looking for another spot.
  3. mr88cet
    mr88cet Senior Member
    2,313
    1,335
    Austin, TX
    Yip...
    I gather that it can give proximity warnings in general, though.
    iPhone ? Pro
  4. Since2002
    936
    1,098
    Duluth, GA
    Using sonar. Reading lines would use the video from the backup camera. In fact I am guessing that the parking assist uses the sensors while parking, I suspect it only uses the video as an interface with the driver for selecting the spot.
  5. mr88cet
    2,313
    1,335
    Austin, TX
    Every source I've heard agrees with your conclusion here.
    iPhone ? Pro
  6. I'mJp
    I'mJp Senior Member
    628
    552
    Ma, USA
    If it could read lines... I would wind up painting lines in my garage.
    That would be cool.
  7. El Dobro
    El Dobro A Member
    7,106
    3,282
    I would be surprised if there's any plug-in car that you can drive off while plugged in.
  8. shebobg
    shebobg Junior Member
    46
    Woolwich Township, NJ
    Can you leave the cord plugged into your outlet without damaging it? I don't bother keeping the cord in the trunk and leave it in the garage. I plug it in just about every night and wondered if you could save time by just leaving it in the outlet.
  9. El Dobro
    El Dobro A Member
    7,106
    3,282
    Not a problem at all.
  10. mr88cet
    2,313
    1,335
    Austin, TX
    As I recall, one of Optimus Prime's YouTube videos said that he unplugs his from the wall because it seems to burn some -- not much, but some -- power even if it's not charging the car.
    iPhone ? Pro
  11. bisco
    52,886
    sounds right. i leave mine plugged in, but it probably uses some electricity, like most electric appliances, even when they are off. we do have members that unplug everything when not in use.
  12. SubPrius
    SubPrius Junior Member
    31
    Can anyone walk up and open the charging port cover?
    Or does the cover have to be released from the inside to cause it to open?
  13. I'mJp
    I'mJp Senior Member
    628
    552
    Ma, USA
    Anybody can open.
  14. Lee Jay
    Lee Jay Senior Member
    5,850
    4,036
    Westminster, Colorado
    That's a part-truth. It only applies to the Plus model. The Premium and Advanced have the locking system.
  15. mr88cet
    2,313
    1,335
    Austin, TX
    Good info! Thanks. One of the YouTube videos mentioned in passing that you needed to have the key fob to be able to open the door. Wasn't very clear about that though...
    On a somewhat-related note, I gather from YouTube there are three settings for locking a charger to the charge port:
    - Manual = hit a button in the charge-port area to lock or unlock.
    - Auto-lock = locks down automatically when you start charging, and must manually unlock it.
    - Auto-lock and -unlock = locks down automatically when you start charging, and unlocks automatically when charging is done.
    I presume that, in auto-lock and -unlock mode, you can also still hit the button to unlock when needed.
    iPhone ? Pro
    #35 mr88cet, Mar 5, 2017
  16. martydallas
    martydallas Member
    106
    84
    Dallas, tx
    You are exactly accurate I like seeing photos as well and thought I would share this so others could see what happens
    The car appeared to start or at least be in the on mode but I could not do anything with the shifter
    Data Daedalus and Prius from Dad like this.
  17. bisco
    52,886
    it even tells you if you left the charge port door open, although it does let you drive like that.
    HPrimeAdvanced and Data Daedalus like this.
  18. Since2002
    936
    1,098
    Duluth, GA
    The Ready light wasn't on so the car wasn't "running". The equivalent to a regular gas powered car turning the ignition switch to On but not starting the engine. Of course in a Prius the engine isn't always running, so the concept of whether the car is "running" or not can seem a bit ambiguous. That's what the Ready light is for, to remove any ambiguity about whether or not the car is "running".
  19. Piwacet
    Piwacet Junior Member
    36
    San Francisco
    You know those videos of rockets launching payloads to space? there's the umbilical cords and hoses that are attached to the rocket that jettison just after takeoff, sometimes it seems as if they jettison after the rocket has just begun to move?
    That's how my charging cord works. Keeps it fully charged until the very last moment! :)
  20. PT Guy
    PT Guy Senior Member
    1,085
    713
    Washington, the state
    The charging system tells the supply when to shut off. If the blue lights on the dash are off and the green light on the charge station is off, it isn't charging, isn't making any difference. Unplug at your convenience.
