Remove steel pieces in transaxle castings?
Discussion in 'Gen 2 Prius Technical Discussion' started by MGpwr, Jun 2, 2018.
  1. MGpwr
    MGpwr Member
    Not far (enough) from Asheville, NC
    Business Edition
    Has anyone done this on the Gen2 T/A? I can't see anyway to get the steel pieces out without ruining the casting, but I'm just an amatuer(sp?) so hoping for some ideas or helpful info.
  2. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,080
    Columbia, SC
    Pictures of what you are trying to describe? Having a difficult time visualizing it.
  3. MGpwr
    MGpwr Member
    Business Edition
    Here's a couple pics - it's hard to show in pictures that there's no access to the other side of these parts, be easier to show in a video; maybe I'll run it by a local rebuilder and see what they say.
  4. Stimp
    Stimp Member
    53
    North Carolina
    Looks like the parking pawl. This video may help:
    Interesting project, may I ask where in NC? I'm in the Triangle .
  5. Dxta
    Dxta Senior Member
    1,932
    769
    Lagos
    What are you trying to achieve?
  6. MGpwr
    MGpwr Member
    Business Edition
    That's a good video, have watched it a few times; they don't say much about the steel bits though, nor do they remove any of them. (I wonder if the big guy has done any other videos on his homemade 3-phase generator, I'd like to see what that thing can do.)
    I'm near Asheville.
    #6 MGpwr, Jun 3, 2018
  7. MGpwr
    MGpwr Member
    Business Edition
    Sooner or later I'll take the castings to the scrap yard, where they will knock the price down if the cast aluminum has steel mixed in with it; hoping for a better tool than a sledge to remove the steel pieces with 8^).
  8. edthefox5
    edthefox5 Senior Member
    10,096
    4,831
    Clearwater, Florida
    Pretty easy to see the one large lever is held in by the black pin. Remove the other side of the trans and drift that pin out. The smaller lever I can clearly see a hex key.
  9. Stimp
    Stimp Member
    53
    North Carolina
    Yeah, that video reveals a lot of mystery, especially the simplicity and isolation of the gears and atf. Seems like some cutting, heating, and maybe pressing to get that out. I'm guessing it's hardened steel to boot. Good luck!
  10. ChapmanF
    17,347
    I would look for the Weber Auto transaxle teardown videos; those are pretty thorough.
    I guess if you're just after the per-pound aluminium scrap price, it doesn't matter that much if you mar it....
    -Chap
    qettyz likes this.
  11. edthefox5
    10,096
    4,831
    Clearwater, Florida
    No that black drift pin is held in by the 2 casing flanges.
  12. qettyz
    qettyz Active Member
    181
    206
    Finland
    Youtube user WeberAuto has tons of superb videos from Toyota Hybrid systems. Including complete re-assembly of Gen2, Gen3 and Gen4 transaxles for example.
    #12 qettyz, Jun 3, 2018
    MGpwr likes this.
  13. MGpwr
    MGpwr Member
    Business Edition
    One would think so, but, the other side of the trans from that black pin is solid aluminum...see pic.
    I know what you mean in mentioning a hex key, it reminds me of that, too, but that's not what that is; I think that it was 'robotically staked' there, or something.
  14. MGpwr
    MGpwr Member
    Business Edition
    I've got several of those, (but on a malware-infested drive at the moment) covering the Gen1 thru Gen3, all of which I found rewarding to watch. I'll have to go back and review what's there now that my focus has changed
    True, that, as well as learn what I can along the way; was just hoping that I was missing something in seeing the way to disassembly.
  15. MGpwr
    MGpwr Member
    Business Edition
    It's definitely not going any where, that's for sure!
  16. MGpwr
    MGpwr Member
    Business Edition
    Thanks, I'll probably just take the cash penalty rather than risk catching schrapnel from hammer hits. However, if I had a cutting torch I'd definitely give that a try.
    #16 MGpwr, Jun 3, 2018
    Raytheeagle likes this.
