Removing cats permanently - is a test pipe all I need?
Discussion in 'Gen 2 Prius Accessories & Modifications' started by Waco440, May 10, 2020.
  1. Waco440
    Waco440 Junior Member
    Three Touring
    I am going to be permanently removing the cats on my 2007 Prius. That being said, is there a direct bolt in replacement for this space or will a muffler shop have to fab up a straight pipe? I found "test pipes" online, are those pipes direct replacements of the cats?
    SM-G986U ?
  2. Mendel Leisk
    42,322
    Welcome. Just joshing, this sounds like the quintessential cruelty to felines thread...
    If you need to get the car through an inspection, the lack of O2 sensors will maybe nix the plan?
  3. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,804
    2017 Prius c
    AND in some (most?) states, a real muffler shop won't do that because it is technically illegal, even if that area does not have mandatory testing.
  4. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
  5. Leadfoot J. McCoalroller
    8,281
    7,792
    Pennsylvania
    2018 Prius c
    Theoretically yes. They are made to be installed temporarily when performance-testing a car on a dynamometer or race track.
    The trouble is, I don't think you'll be likely to find one meant for your Prius, because not very many racers are operating a Prius. There's not much demand for a prefab specialty part like this.
    If you make one yourself and ignore the P0420 error light you'll probably do okay. In some states you might be able to get a muffler shop to fabricate one for you, but in other states they may decline the job due to state emissions law.
  6. Waco440
    Three Touring
  7. Waco440
    Three Touring
    I won't have a problem with that. Thanks
    SM-G986U ?
  8. Mendel Leisk
    42,322
    @JimboPalmer interesting link. But what's happening in the last sentence; maybe I should turn on the news:
  9. ETC(SS)
    7,528
    Answer to the question:
    No.
    In my 10 years with Priuses I've never heard of one.
    As mentioned above, "test pipes" are not commonly used on vehicles powered by a 4 cylinder Atkinson engine.
    As Jimbo pointed out It would probably be cheaper just to put a non-oem cat back on.
    If you're looking for performance or fuel economy improvements....getting rid of the cat isn't going to do it - especially on an 07, and there are less-restrictive cat-back options to give you the fart-can sound or other "benefits".....real or imagined that you might be looking for.
    #9 ETC(SS), May 11, 2020
  10. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    I am not sure exactly how you typo New York into Chile, but I suspect it takes the repeated application of alcohol.
  11. fotomoto
    fotomoto Senior Member
    5,639
    3,815
    So. Texas
    Common modification the m/c world when chasing max hp gains from intake/exhaust mods and lowering weight. A straight pipe is welded inside the gutted cat which was cut opened from the top/unseen side. O2 sensor eliminators are needed for the CEL you'll get. Some muffler shops will do it for off-road/competition use or a welding shop will do it no questions asked.
    GOOD LUCK!
  12. fotomoto
    5,639
    3,815
    So. Texas
  13. Waco440
    Three Touring
    Waco is nearest big town to me. Thanks, I'll keep that for when my batteries go down the road.
    SM-G986U ?
  14. fotomoto
    5,639
    3,815
    So. Texas
    Matt offers several (common) repair services also. Remember, these are drive-to-you offers and you should be in his 150 mile service area.
  15. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,801
    Undisclosed Location
    When I read the headline, I thought I was going to have to report this thread to PETA or the Humane Society.
  16. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    In theory it bolts to the manifold and there is an included clamp to attach to the rest of the exhaust. I would consider welding it to the rest of the exhaust to reduce noise, but that is me.
  17. ydpplqbd
    ydpplqbd Active Member
    551
    254
    If you go this route, you can likely avoid the P0420 CEL with a simple mod. On ebay, O2 extenders are sold with catalyst built in. IOW, catalyst only catalyzes air/fumes analyzed by the downstream O2 sensor which should avoid the P0420. Food for thought.
  18. dorifutoben
    dorifutoben New Member
    San Antonio
    My cat got stolen 4 nights ago.. Thinking of doing the same thing as OP. They can't steal a cat again if there isn't any O.O My question is how much louder would it be? Has anyone this? Replacing only the section from the flange up to the resonator?
  19. ETC(SS)
    7,528
    P.C. Answer:
    You should always replace a cat with a cat. If you live where they make you pay a special tax for driving Priuses and you have to replace an OEM cat with an OEM cat, then you should do your part to save the planet, the whales, Toyota manufacturing, etc...etc...
    Real World Answer:
    If you live on free soil, you should consider replacing the OEM cat with an aftermarket unit, and keeping the O2 sensor where it is.
    Your car will run more efficiently and you'll still be doing your part to lower car emissions.
    However (comma!!) I can report that there are about 432,000 ways that you can bypass the cat and I can also report that a test pipe to the muffler will leave your car sounding much like it did before your cat was stolen (catnapped?)
    I mentioned the PC answer first NOT to curry favor with the eco-chic in the forum (NOTHING could accomplish THAT!) but rather because aftermarket catalytic converters are inexpensive enough to warrant putting a cat back into the car, although I would also consider clearly labeling it as a NON OEM unit to make it less attractive for thieves wanting to use it on the black market.
    Good Luck!
    dorifutoben likes this.
  20. oldtechaa
    oldtechaa Active Member
    336
    225
    NZ
    2013 Prius Alpha
    Aftermarket cats really are quite cheap, it's illegal to remove the cat permanently no matter where in the US you may live (even though without inspections it won't really be discovered) and the benefits are immense. Please just put an aftermarket cat on. There's no downside to it. You could remove and sell the OEM cat, install an aftermarket cat, and make a profit on it. You haven't said why you want to remove it, though.
    PA Prius likes this.
