Removing door panel upholstery
Discussion in 'Gen 3 Prius Accessories and Modifications' started by radioprius1, Aug 21, 2009.
  1. radioprius1
    radioprius1 Climate Conspirisist
    1,355
    155
    Iceland
    Hi guys,
    I'm wanting to remove my upholstered door panel inserts so I can leave them at the upholstery place to get covered in some nice leather. I pulled my door panel off today and I see the upholstered insert is held in place by a lot of little plastic looking rivet things. They don't appear to have a screw head on them.
    I have included photos of them.
    My questions are:
    1. Does anyone know the best way to remove these little rivets?
    2. More importantly, how would you reattach the upholstered inserts?
    Thank you kindly for any advice,
    RP1
  2. mgb4tim
    mgb4tim Noob
    1,153
    111
    Pittsburgh, PA
    I can't tell from the pictures, but is it a stem that comes out and is melted over the back of the insert?
    I was considering the same (but will do it myself, since I'm so darn "thrifty")
  3. radioprius1
    1,355
    155
    Iceland
    Yes! That's exactly what it seems like. Removing them should be easy enough, just find some way to cut them. I just wonder about reattaching them. Does anyone have TIS access that could look anything like this up?
  4. d2mini
    d2mini Active Member
    519
    106
    Houston
    I know this is an old thread but I was wondering if anyone ever figured this out?
  5. SoCalBPrius
    SoCalBPrius Active Member
    563
    118
    SoCal
  6. d2mini
    519
    106
    Houston
    You rock! Thanks!
  7. SoCalBPrius
    563
    118
    SoCal
