Removing Front power seat concern
Discussion in 'Gen 4 Prius Technical Discussion' started by G23, Sep 25, 2018.
  1. G23
    G23 Junior Member
    28
    I Plan on installing some amps under the front seat so I have to remove it. Is it necessary to disconnect the battery before doing that? Also, I need to make adjustments to gain after install so I will need to turn the car on while the front seat is still removed. Will this cause any problem such as codes or airbags, etc? Thank you.
Loading...
