removing rear seats
Discussion in 'Prius v Main Forum' started by autopc, Mar 29, 2012.
  1. autopc
    autopc New Member
    57
    midwest
    A friend wants a '12 Prius V III. He might need a little more space in the rear. Has anyone removed the 2 rear seats before? Anyone know if it can be done and how to do it?
  2. Keiichi
    Keiichi Active Member
    808
    79
    Goleta
    I have not personally seen if you can remove the seats, although I do question if that is a wise decision to remove instead of just lowering the seats to make the room. I believe that in the Prius v, they also have the battery vents under the back seats, or so I am led to believe, similar to the Prius.
    Space wise, you would probably only gain maybe about 1.5' in depth at most for a small block area.
  3. seilerts
    seilerts Battery Curmudgeon
    3,326
    1,520
    38
    Santa Fe, NM
    2 people like this.
  4. autopc
    autopc New Member
    57
    midwest
