Removing the protector cap on the J1772 connector
Discussion in 'Prime Plug-in Charging' started by Tickwood, Sep 13, 2019.
  1. Tickwood
    Tickwood Active Member
    334
    101
    San Diego
    2020 Prius Prime
    Twice already I have tried to close the charging point door with the rubber/plastic protector cap dangling. Is there any real world reason not to just take it off? The connector is still protceted behind the door.
  2. jb in NE
    jb in NE Senior Member
    2,233
    1,599
    Nebraska
    2018 Prius Prime
    The door is not gasketed. Dirt and water can still get in behind the door, and if the connector is open then the connector will get dirty or wet. I would not remove the protective cover from the plug.
    TGrracie and jerrymildred like this.
  3. Salamander_King
    Salamander_King Senior Member
    11,024
    8,976
    New England
    I wonder what Japanese version of PRIME (Prius PHV) have in the charge port. As I understand, Japanese Prius PHV has CHAdeMO port at where the North American version of PRIME use as cap holder (arrow in the diagram). Do they have two separate caps for both J1772 and CHAdeMO connectors and no placeholders?
  4. Salamander_King
    11,024
    8,976
    New England
    I found the answer. This photo from Japanese Toyota site shows two separate protector caps.
    jerrymildred likes this.
  5. CharlesH
    2,798
    1,166
    Roseville, CA
    Too bad that they couldn't just build the cover into the door, like they for the PiP (2012-2015 PlugIn Prius). All you had to do was shut the charging port door, and the protective cover went into place.
  6. jerrymildred
    jerrymildred Senior Member
    11,517
    14,164
    Tampa, FL
    It almost seems like the engineers looked at it and decided it was way too convenient, so they changed it to something more complex. "It it ain't broke ... hurry up and break it!!" :confused:
  7. walterm
    walterm Active Member
    466
    202
    34
    2022 Prius Prime
    No, the engineer's slogan is "If it ain't broke, open it up and fix it!"
    noonm and jerrymildred like this.
  8. noonm
    noonm Senior Member
    575
    595
    2018 Prius Prime
    I believe we call that "job security" :)
    As one who occasionally charges outside in the rain/snow, I do prefer the door to not be water tight so it will dry out after I close it.
  9. bisco
    52,677
    pip door isn't watertight, the plug cover is attached to it, and protects the plug when you close the door. simple, and elegant
    jerrymildred and noonm like this.
  10. vvillovv
    vvillovv Senior Member
    4,336
    1,517
    NY
    Does protective cap consistently fall out of its holder and dangle on your car
    I've had a hard time getting that damned cap to stay in there once or twice and that is frustrating enough for me.
  11. john1701a
    john1701a Prius Guru
    12,840
    5,312
    58
    Nope. The trick is to just turn it a little. That tightens the grip.
    Exactly! I've had mine covered in a blanket of snow quite a number of times. It dries out fine.
    vvillovv and jb in NE like this.
  12. jb in NE
    2,233
    1,599
    Nebraska
    2018 Prius Prime
    Thanks. Good tip.
  13. jerrymildred
    11,517
    14,164
    Tampa, FL
    Interesting. Mine just stays. No special technique required. In fact, it takes a little tug to pull it out and makes a small squawk.
    Then again, I don't think mine ever got used till I bought the car in March this year. Maybe a wear issue? Did yours come loose when new?
    But I can't help wondering whether it would be possible to find a PiP charging door and retrofit that inner panel to the Prime's door. I haven't looked because I don't imagine there are very many PiPs in the junk yards yet.
    Prius from Dad likes this.
  14. jerrymildred
    11,517
    14,164
    Tampa, FL
    I can't count the number of times I've done that myself!! :ROFLMAO::ROFLMAO::ROFLMAO:
  15. Dennis_MA
    Dennis_MA Active Member
    185
    109
    Amherst, MA
    No problem with the cap here. I pretty much charge every day and the cap fits fine in the holder while charging. Very rarely does it come out. Usually my fault for not fitting it correctly in the holder.
  16. vvillovv
    4,336
    1,517
    NY
    Once or twice on a dark cold snowy night I've had issues with that cap staying in it holder. Maybe the night light in the charge well was obscured by snow or something like that, I don't really remember all the details.
    I have been frustrated when pushing the on button only to see the notice on the MID that the charge door is open. Usually when I'm late besides.
  17. Tha_Ape
    Tha_Ape Active Member
    271
    162
    Washington, DC
    Is it possible to buy the Japanese charger and install it in a US prime (and have it work)?
  18. Salamander_King
    11,024
    8,976
    New England
    If you are thinking of CHAdeMO, then the answer is simply NO.
  19. patcoghm
    patcoghm Junior Member
    57
  20. Billy sharpstick
    Billy sharpstick Junior Member
    Micanopy FL USA
    2019 Prius Prime
    It would have been so simple to just engineer a rubber gasket all around the door.
