Removing the rear seat headrests for better visibility
Discussion in 'Gen 5 Prius Main Forum' started by deev, Mar 31, 2024.
  1. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,427
    2,393
    Taylors, SC
    Cover the holes with 3/8 inch nylon hole plugs available in black or white from Lowe's or Ace Hardware.
  2. Blackat
    Blackat Active Member
    446
    309
    Colorado
    2023 Prius
    Limited AWD-e
    Why?
  3. Trollbait
    12,466
    I'd say mostly for aesthetics, though there is a slight chance something could get stuck in there.
  4. Georgina Rudkus
    3,427
    2,393
    Taylors, SC
    Have kids?
  5. Trollbait
    12,466
    That was a consideration, but idle hands can also remove the plugs.
  6. Georgina Rudkus
    3,427
    2,393
    Taylors, SC
    The plugs have thin flush edges which make them quite difficult to remove. Also, the side adjusting and retaining button must also be depressed at the same time.
  7. KMO
    KMO Senior Member
    1,916
    657
    Finland
    2023 Prius Prime
    Wow.
    Are the locking mechanisms compatible? The non-US ones are retractable, with a few positions, like the front headrests. I guess the US ones would still use the same notch mechanism to hold them in, although it looks like you wouldn't be raising them.
  8. deev
    deev Junior Member
    47
    usa
    2024 Prius Prime
    XSE Premium
    I am actually trying to find the "smaller" headrest version installed in Taiwan. Although - maybe I should just wait until some third party comes out with a "foldable" version.
  9. Hammersmith
    Hammersmith Senior Member
    2,271
    2,269
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    Crap. I copy pasted the wrong section of my interior conversion doc(I researched this all months ago for the same reason you're doing it). Sorry about that.
    Here are the correct part numbers for the smaller headrests:
    71940-47710-C5 - Black leather with red stitching (XSE, XSE+)
    71940-47710-C6 - Black leather with silver stitching (XLE/LTD)
    71940-47750-C2 - Black cloth with red stitching (SE)
    71940-47750-C3 - Black cloth (LE)
    71940-47730-C3 - Black (not exactly sure about this one - minimal description in the parts catalog)
    No gray interior in Japan
    ¥17,300 each = ~$112.50
    #29 Hammersmith, May 6, 2024
    deev likes this.
  10. Hammersmith
    2,271
    2,269
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    I corrected the part numbers(I accidentally originally pasted the US headrests, not the Japanese ones), but I did confirm the locking mechanisms are the same. The channels in the seats that the headrests slide into are the same part numbers in all Priuses worldwide. Well, there are actually four different ones, but they are only cosmetically different as they're linked to each interior color/material(black leather, black fabric, gray leather, gray fabric).
    And the seat frames are the same as well. At least the 40 of the 60/40 split is the same. The 60 is different but only because the Japanese 60 has a separate headrest while the US 60 has the headrest built in.
