Repaint/Powdercoat Wheels...Cost?
Discussion in 'Gen 3 Prius Accessories and Modifications' started by qdllc, Jul 21, 2015.
  1. qdllc
    qdllc Senior Member
    1,377
    400
    Just for consideration, what would it likely cost to have wheels repainted to match the car body with a quality job that will hold up over time?
    92 views, no replies. o_O:(
    #1 qdllc, Jul 21, 2015
  2. el Crucero
    el Crucero Senior Member
    1,628
    699
    Inland Empire
    I have researched this option. From my research, powder coat will be MUCH more durable than paint. The problem with powder coat is that you have a very limited selection of colors. You will not be able to color match your exterior. For me, it is not that big a problem since my Prius is Blizzard Pearl and white powder coat will be close enough. I haven't made a final decision yet.
    The prices I have been quoted locally in Southern California are:
    - powder coat in white = $70 per rim
    - paint (3 stage) to match Blizzard Pearl = $100 per rim
    - (in addition) to chrome OEM wheels about $150 to $200 per rim
    The prices do not include dismount, remount, and balance. The durability of each of these options will depend on: 1. how often you clean and wax your wheels, 2. whether you drive in snow with salt on the roads, 3. whether you live near the beach, 4. the amount of impurities in the OEM rim (or any aftermarket rim for that matter). Let us know what you decide.
  3. qdllc
    qdllc Senior Member
    1,377
    400
    Ouch.
    I figured color-matched wheels would look better than the OEM wheel covers. At least I now know what kind of $$$ I'd be spending if I wanted to do it.
  4. el Crucero
    1,628
    699
    Inland Empire
    You have one more option. You can Plasti Dip your rims for abut $10 each if you do it yourself. Again, you have limited color choices and you will not be able to match your body color. The coating will last about 3 or 4 years and then you will have to re-apply the coating.
    #4 el Crucero, Jul 27, 2015
  5. nsb
    nsb Junior Member
    33
    Hawaii
    how hard is this process? can an noob do this?
  6. rcs3434
    rcs3434 Member
    56
    163
    Danbury, ct
    Plasti dipping isn't hard, I think it's actually easier than spray painting. When I first learned about it I did my rims with spray cans with no experience, came out good. Prep and coats is most important for peel ability.(1 can per rim) Now I'm on my third color for my whole car, and thinking of my next:whistle:
    nsb and Burna J like this.
  7. zzrguy
    zzrguy Junior Member
    88
    23
    ny
    Picture please. Of those plastic dipped rims
  8. saulbassfan
    saulbassfan Senior Member
    979
    3,108
    Southern California
    Try getting quotes for powder coating in your area. In California you can get a set done for about 250 dollars. These places usually will have swatches you can see if you want to get close to your body color.
  9. el Crucero
    1,628
    699
    Inland Empire
    Click on the words "Plasti Dip" in my quote above and it will take you to a video of application to answer your questions.
  10. zzrguy
    88
    23
    ny
    Ok thanks
  11. rcs3434
    rcs3434 Member
    56
    163
    Danbury, ct
    These are off a 2010 so they were silver to black
    Then did a blue/green chameleon
  12. Mendel Leisk
    42,333
    Toyota used to at least paint the rims silver. This is traditional, looks good with any body color, is widely accepted. Then (in 2012 model year?), I'd suppose at least in part in reaction to owners pulling off the wheel covers, they switched to painting the rims black, which is way over at one extreme, prized by boy-racers only.
  13. JC91006
    16,936
    8,647
    Black paint must be cheaper than silver paint
  14. nsb
    nsb Junior Member
    33
    Hawaii
    Thanks a lot, that seems pretty easy!
  15. Blizzard_Persona
    1,787
    948
    Pa.
    2023 Prius Prime
    XSE
    Is powder coating gold color an option? Or is it only able to be done in black?
    I don't think there is gold plastidip right? If there is I might throw a few coats onto the Personas rims.... I think it would look sick with the white paint and black windows....
  16. KennyGS
    KennyGS Senior Member
    1,243
    1,046
    Keystone State
  17. el Crucero
    1,628
    699
    Inland Empire
    check with your local powder coater. Most don't have all the colors. If it is a special order color, the cost can skyrocket!
    Go to plastidip.com to view the available colors.
  18. zzrguy
    88
    23
    ny
    True Metallic Wheel Kits
    it's under true metalic
    the more I read on this stuff the more I like it.
    I might try this first to see if I like the color and then have the rims powder couted latet
    #18 zzrguy, Jul 29, 2015
    Blizzard_Persona likes this.
  19. NickInNJ
    NickInNJ Junior Member
    61
    New Jersey
    better to get new rims, costco has the velox 17's for $399
  20. el Crucero
    1,628
    699
    Inland Empire
    That depends on your priorities. If I switch to 17's from my OEM PIP 15's it will cost me as much as 5mpg's on my efficiency. I am going to have my 15's powder coated so I can keep my 70 mpg average.
