Repair or Sell? Seeking advice
Discussion in 'Gen 3 Prius Main Forum' started by TRX, Oct 5, 2024.
  1. TRX
    TRX Junior Member
    Los Angeles
    Hello all, longtime reader, first-time poster.
    I have a 2011 Prius with 156k miles facing some potentially heavy repairs. I've listed them all, with complete service history below. For those of you who've seen a lot of these, I'm seeking advice whether to repair or invest in a newer prius / older Toyota (I don't have much $ to spare right now).
    I can probably do brakes and suspension myself, but I'm not sure whether it's worth stacking a bunch more miles on this car or if I'm just going to keep having problems. I know 2011 isn't the best year.
    Thanks so much for your advice!
    Upcoming Repairs:
    Brake Booster / Actuator (seems to be gradually failing since 150k, but unsure)
    Front Suspension (totally shot)
    Full Brake replacement
    EGR valve seems to needs cleaning
    Hybrid Battery getting lower..
    Also need new tires...
    Complete service history (w/ regular oil and tire rotations):
    150k - cat converter replaced
    11/23 - new 12v
    141k - sway bar links
    130k - new head gasket, spark plugs, egr cooler
    103k - wheel hub, bearing, passenger
    100k - spark plugs
    90k - hybrid inverter (under warranty)
    68k - purchased at 15.1k 7/4
  2. ForestBeekeeper
    ForestBeekeeper Active Member
    780
    310
    Maine
    What do you mean when you say: "Hybrid Battery getting lower.." ?
    What is lower?
  3. douglasjre
    douglasjre Senior Member
    2,250
    751
    Null, NL
    I'd do the repairs and keep it
  4. rjparker
    rjparker Tu Humilde Sirviente
    11,103
    6,967
    Texas Hill Country
    Cat changed 6k miles ago… is the engine an oil burner?
    What does the body, paint and interior look like?
  5. bisco
    52,855
    i would do the minimum necessary to sell it, if you can find a non hybrid you can afford.
  6. TRX
    TRX Junior Member
    Los Angeles
    Honestly , I’m being a bit dramatic. It was around 50% the last time I checked Dr Prius. Just thinking long term I guess.
  7. TRX
    TRX Junior Member
    Los Angeles
    I get oil changed every 5-6k and the engine oil issue has never been raised with me. I know it’s common on some of these. Cat was stolen that’s why it was replaced.
  8. ForestBeekeeper
    780
    310
    Maine
    Unless it is actually setting a code, your drive battery is likely good for another 100k miles.
    Another question for you, why do you think your EGR needs to be cleaned?
    Have you or your mechanic seen any indication that the EGR is clogged?
  9. Eddie25
    Eddie25 Active Member
    503
    213
    MI
    Also why do you think the brake booster is failing? What does "suspension shot" mean? What do you mean by full brake replacement?
    To answer your question much more details are needed. As far as a financial decision you'd also need to include details about how much you drive, how much you might spend on a new car, mpg of said car, how do you use your car, etc. I'm not saying you have to answer those here, but you need to factor them in.
    With a head gasket already having been done it's definitely in contention for being a keeper especially if you have DIY ability.
    My HV battery was rated 50% by Dr. Prius 6 years ago. Pure conjecture by me, but I'd think there's more cars making it to 250k+ with the original HV battery than with the original brake booster system or head gasket.
    bbrages likes this.
  10. rjparker
    11,103
    6,967
    Texas Hill Country
    You need 5 posts before you are realtime around here. Plus if you use iOS you need to refresh at least once everytime you do anything including looking for alerts, edits or recent activity. Otherwise the system here does not update even after hours.
  11. ForestBeekeeper
    780
    310
    Maine
    With our two Prii, we have gone through multiple brake boosters that is not a big deal.
  12. Mendel Leisk
    42,347
    I would take this as an answer:
    Purrius likes this.
  13. Eddie25
    503
    213
    MI
    New EGR cooler at 130k though. In my limited experience the EGR valve itself doesn't typically get clogged. It might be worth checking the EGR runners on the intake, but it's still worth asking "why?". There's a decent chance they were cleaned when doing the head gasket.
    douglasjre and Mendel Leisk like this.
  14. TRX
    TRX Junior Member
    Los Angeles
    My engine shook quite a bit the other day upon a cold start. Only had that happen before the head gasket blew. It's been fine since, but made me wonder if the EGR needs cleaning.
  15. TRX
    TRX Junior Member
    Los Angeles
    Not cheap though, and way above my paygrade for DIY..
  16. Eddie25
    503
    213
    MI
    Cold start shakes are only associated with the EGR in that people think that the clogged EGR is the cause of the blown head gasket, which is the cause of the shakes. There's other scenarios that cause the cold start shakes as well. I personally wouldn't put too much stake in that diagnosis. What about the other stuff?
  17. bisco
    52,855
    couldn't clogged intake manifold ports cause the shakes?
  18. Mendel Leisk
    42,347
    I suspect the shakes are near-invariably due to some sorta liquid in the combustion chamber, either drawn in through the PCV and/or EGR feeds, or coolant getting past the head gasket. The former seemed to be a consequence of just running the engine a few seconds, the day previous.
  19. TRX
    TRX Junior Member
    Los Angeles
    Reviving this thread. Finally got the famed C1391 code. I have two questions for the smart folks here-
    1) how do I know whether I need to replace just the cylinder or the actuator or both?
    2) I’d love to DIY this repair, especially if it’s just the cylinder. But I don’t have the tools, especially to bleed. Anyone in Los Angeles that I could lend from or team up with in exchange for some cash?
  20. indel
    indel Member
    283
    89
    Northwest Indiana
    There is a 20% off plus free shipping promotion that many dealers are currently running on autoparts.toyota.com. It expires in 24 hours. I would get both parts. Bleeding shouldn't require any specialized tools. Do you have Techstream? Or an Autel AP200 bluetooth adapter?
