Repair questions - 2011 Prius 245k miles
Discussion in 'Gen 3 Prius Main Forum' started by Ds001001, Oct 19, 2022.
  1. Ds001001
    Ds001001 Member
    81
    34
    Tahoe North Lake
    Last month I bought a cat less 2011 since then I’ve put in a new aftermarket cat in and prolong’ed the battery. Some questions as I’m going into the engine bay starting tomorrow.
    My appointment at the dmv to get it registered is in 4 weeks, so I have plenty of time to do stuff to it.
    In an EGR replacement video, the guy mentioned that there is a special package (and cheaper) part number that includes an egr valve, gaskets and a pcv valve. I haven’t been able to find it on parts.Toyota.com. Has anyone seen that? It’s not linked in the video
    I’m leaning towards replacing egr valve, cleaning the cooler and intake manifold.
    Is there a way to look at the engine coolant water pump and tell if it needs replacement ? Or given it’s age should I just replace it?
    is inverter water pump something I should do too ?
    I’m intrigued by the gen 4 engine into gen 3 idea, am I reading the latest correctly that they’re using gen 3 intake manifold and egr valve in the ones that are working well ? (I can’t seem to find any success stories documented, more of people just asking questions). So if I replace intake manifold too I wouldn’t be wasting money if I do gen 4 convert ?
    I have a year old hv battery in my gen 2, the modules can be ported to the gen 3 , correct ? If so, is there an easier way to do it than complete disassemble ? (Ie without unscrewing all the bus bars/etc… unscrew the pack with the white plastic end pieces and attach to the gen 3 case ?)
  2. rjparker
    rjparker Tu Humilde Sirviente
    11,094
    6,961
    Texas Hill Country
    What problems are you trying to solve?
  3. JC91006
    16,936
    8,647
    If this were my car, I would try to find out if it's any good before pouring money into it.
    1. I would definitely clean the EGR circuit, cooler, intake manifold. That's just basically labor and free of replacement parts
    2. Swap over your good battery modules to this car (what are you going to do with the gen2?)
    That should be good enough to drive for a while until you figure out if this is a good car or a lemon (see how much oil it burns)
    You can spend money on the inverter pump, water pump, coolant changes, transaxle fluid change, spark plugs, and all the good maintenance items later. You'll eventually need to start replacing parts as this car has a good amount of mileage on there.
  4. Ds001001
    Ds001001 Member
    81
    34
    Tahoe North Lake
    My dilemma is now that I have 2 cars , gen 2 that I spent 5k on last year and drives like new and a 2011 that looks like new with all the bad things haven’t happening yet. I wouldn’t want to get rid of g2 unless I swapped in a 40-50k mile jdm to the gen 3.
    As far as I can tell the 2011 has no issues now that need fixing, but any of the issues like either water pump breaking and the cost would be more than the parts today, But I guess super AAA would solve the concern of something wrong happening at the wrong place.
    I figure since I got it for $1000 why wouldn’t I spend another 1 or 2k for the parts of stuff I can do on my own. Then decide next summer on a jdm engine swap (g3s are listing at under $1000 so maybe $3000 with labor and g4s are listing 1500-2000 so $4000 with labor ) and I’m all in at $8000 with a car that should last another 100k miles. Then sell the gen 2 and I’ve traded up for $3-4000.
    I guess I could drive it all winter around the basin when I’m not doing any large climbs (to squaw/alpine from my town ) in combo with AAA and should be fine to get a good baseline on what’s happening with it.
  5. JC91006
    16,936
    8,647
    A 3rd gen head gasket issue won't just suddenly happen without warning. I think if it hasn't happened yet, you can pretty much just clean the EGR circuit, cooler, intake, change water pump and coolant, those items alone should be fairly easy and should prevent the dreaded gasket failure. Your friend with the Jeep, he can help do all that stuff right? Then you'll have a pretty decent car to drive around until the brake actuator fails (this can happen to both gen 2 and 3)
  6. Ds001001
    Ds001001 Member
    81
    34
    Tahoe North Lake
    That was one option I didn’t even think of yet, I could have a 2015 engine shipped to ridgecrest and put it in there. I mainly get access to tools/car port plus moral support as he’s pretty busy, but I could probably get help with a job that big, he has all the things to pull engines out.
    The water pump change video I watched doesn’t look that hard, seems pretty accessible after taking off the air filter stuff you take off to get to egr and intake manifold. Although he didn’t burp the cooling system like a gen2 when done , he just filled the side tank after opening/closing a valve underneath in the middle between wheels to drain it…and said to watch it and fill it the side tank more as it runs.
  7. JC91006
    16,936
    8,647
    Don't think about pulling the engine until it actually fails. The 2015 won't be any better, you won't notice the difference....you'll notice you have a $3000 hole in your wallet for doing a swap. 2010-2015 engine basically the same, modified piston rings blah blah blah won't do anything but save you a quart or 2 of oil
    Grit likes this.
  8. KamiKKazi
    KamiKKazi Member
    92
    60
    OC
    I have a 2010 and the engine isn’t as bad as they make it sound. I just monitor my oil level. The water pump replacement is easy I got my water pump on ebay from japan for like $145. No need to replace the egr valve. I would clean it and make sure you clean the intake good too through the egr ports. Replace the manifold gaskets, i like the fel pro manifold gasket set for prius. Replace the pcv too, I would go OEM on the pcv valve.
    Foxglove likes this.
  9. ASRDogman
    ASRDogman Senior Member
    8,063
    4,086
    The updated pistons and rings slows the oil blow by, which reduces burned oil going through
    the egr valve and cooler and through passages in the intake manifold which means less chance of
    clogging the cooler creating excessive back pressure which causes head gasket failure and
    less burned oil going through the catalitic coverter cause the very expensive part to fail... but blah blah blah
  10. Noahdoge
    Noahdoge Active Member
    219
    148
    Mississippi
    Here is the part number for the EGR kit.
    04004-58137
    It includes the gaskets and egr pipe gasket but doesn’t include the pcv valve. That’s separate but cheap.
  11. ChapmanF
    19,019
    I used to think that, but there turns out to be a way these EGR valves can go bad, mashed ski-jump syndrome, which I would recommend checking for if you will be working around the valve anyway.
    I used to think it was rare, because the first time I heard of it was from ozmatt, who had been driving really hard uphill on a really hot day.
    But then somebody else reported it, and then I saw my own valve had it.
    If yours has the problem, if you are a very determined DIYer you might fix it up with a hot bent butter knife the way ozmatt did, but the less hard-core way is to replace the valve.
    I believe this problem will show up in your EGR flow test result, so if you've checked that and the number's ok, you probably don't need to check for this. But if you have a lower flow test number that makes you want to clean the cooler and stuff, be sure to also check for this condition of the valve.
    KamiKKazi likes this.
  12. Mendel Leisk
    42,343
    I searched that part number, found it, but there’s no description. What exactly is in that kit? EGR valve for instance? Most of the EGR gaskets are metal, very durable, apart from connection at intake manifold.
    I’ll be doing our EGR again soon, since I’m doing the spark plugs, and will have the wipers/cowl off. I’ve opted to replace all the intake manifold gaskets (including aforementioned EGR connection). More’n likely the last time I’ll be in there, with our low usage, so I thought what the heck.
    Got them through Amayama for about $15 CDN. With roughly $15 for shipping, $30 all-in.
  13. Noahdoge
    219
    148
    Mississippi
  14. JC91006
    16,936
    8,647
    Toyota had a TSB regarding the replacement of this valve, if it's bad, they will replace it. I got mine replaced free of charge when my car exhibited symptoms described in the TSB
  15. Noahdoge
    219
    148
    Mississippi
    The TSB is no longer valid after 150k miles.
  16. ChapmanF
    19,019
    TSBs are just technical service bulletins; they explain something that gets figured out about the car after it went in production. A TSB doesn't have time or mileage limits; it's just knowledge, and it stays knowledge unless some other TSB comes out later with better knowledge. A TSB might describe how to do some sort of repair, but it doesn't say that anybody is going to do it for you for free.
    Then, there are service campaigns, like recalls or warranty extensions. A warranty extension campaign can say that, up until so many miles or so many years, we'll do the repair described in such-and-such TSB for free. After the time or mileage limit, the service campaign doesn't promise you anything for free anymore, but the TSB is still a perfectly valid notice about a problem and how to fix it, if you want it fixed.
    That's what happened here: T-SB-0027-16 is the service bulletin that tells you about a kit containing an updated EGR valve, and an updated ECM calibration to be flashed, and service campaign ZF3 was the warranty extension that said up to 10 years or 150k miles, they'll do that for free.
    So if you're above 10 years or 150k miles, the ZF3 warranty extension won't make anything free for you, but the TSB still tells you the EGR kit and ECM calibration to install, if you want the fix.
    Foxglove and JC91006 like this.
  17. Ds001001
    Ds001001 Member
    81
    34
    Tahoe North Lake
    Hi all, I’m covered in carbon now after getting the cooler and egr valve off and doing some spraying
    The cooler is completely clogged on both sides, brake cleaner just pools in the top after about half a can of spraying ? Doesn’t seem like it’s possible to clean and I need to replace ?
    A note , I drained both inverter and engine coolant before pulling the hoses off the cooler and a cup still remains in the bottom back hose so if you’re reading and haven’t done it before be ready!
  18. Ds001001
    Ds001001 Member
    81
    34
    Tahoe North Lake
    Here are some pics. Hard to get inside the cooler but can see the pooling of the cleaner a little bit A7F8E1B9-BDA3-40E6-B4DD-8A28D257A121.jpeg 0E0B94D0-5619-4E02-802B-BF3FF51F2676.jpeg 7438F6FF-BD4A-4587-8366-7A458A306A52.jpeg 8239F44D-8138-49A4-82E5-B08E7F5274EB.jpeg
  19. JC91006
    16,936
    8,647
    I've read there are benefits of just replacing the EGR valve, especially since yours is pretty gunked up. The cooler itself can be cleaned out using a pressure washer, that for me was the best method in spraying all the carbon out of there (after a good soaking)
  20. ASRDogman
    8,063
    4,086
    A pressure washer, and oven cleaner for the cooler. Wire brush the valve and spray
    brake/carb cleaner down the piston side.
    Spray the oven cleaner in the cooler, both ends, (wear Rubber gloves) and let it sit for 30
    minutes or so, then pressure wash it out. It will be messy!
    Depending on how bad it is, it may take a few times, but it will CLEAN the cooler.
    Ds001001 likes this.
