Repaird the broken taillights
Discussion in 'Gen 4 Prius Main Forum' started by peter, Jan 8, 2022.
  1. peter
    peter Junior Member
    29
    gothenburg, sweden
    In europe most cars have automatic daytime lights. Prius 2016 has too but unlike previous models
    the taillight is off. This is a danger when rain/bad weather etc. There is no point (imho) to not
    turn on the taillight at all times.
    Turning on the full light will turn on the taillights but then the light will not turn off when
    car is turned off. (This SAAB fixed 1971 !!)
    The simple fix is to cover the daylight sensor ( located on the dashboard, a small "bulb") with black tape.
    This permanently set the car in dark mode. The only drawback is that the instrument light will not
    automatically adapt to night setting, but that is easily adjusted with the button. In addition the
    silly LED's wont turn on, the headlights is used.
    pilotgrrl and bisco like this.
    52,431
    my car doesn't have drl's, but if i turn it off with headlights on, i get a warning
  3. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,593
    near Brisbane, Australia
    I just put the parking (side) lights on - the rear lights are then on, with only the parkers at the front. I far prefer, with mostly Motorway driving, to have REAR lights on. And they turn off automatically when I POWER OFF.
  4. peter
    peter Junior Member
    29
    gothenburg, sweden
    How lights work seems to be a regional issue.
    European prius 2016-2020 seems to have broken taillight and will not turn off lights if
    full lights are choosen, instead the car makes noise.
    Running in rain/dusk without taillights is a danger and should be avoided.
  5. alanclarkeau
    7,045
    7,593
    It sounds like its not "broken" at all - just not working the way you want it different to the design.
    Did you try what I suggested in #3?
  6. Harters
    Harters Active Member
    335
    427
    UK
    Excel
    If you are driving in those conditions you should have your dipped headlamps on. I was aways taught, if you think you need to have lights on, then forget side lights, always choose dipped headlamps.
    Even with the automatic headlamps the Prius has, I still override them sometimes when I think visibility is poor e.g. fog as they often will not come on in those situations.
    alanclarkeau likes this.
  7. alanclarkeau
    7,045
    7,593
    Remember the VOLVO 244? I had a 1980, and the brighter than normal front side lights (21w) and the tail-lights came on. Daylight Running Lights I'm sure they called them even back then. But my 1994 VOLVO 940 didn't have them.
    For some odd reason when DRLs became "normal" in the last decade, they didn't think about REAR lights - which I reckon are more important, at least on Motorway driving - where hopefully no traffic is coming the other way. Hence I put side-lights on - which gives Rear Taillights.
    Harters likes this.
  8. Harters
    335
    427
    UK
    Excel
    Yes, I remember the old 244, lovely cars and I remember people saying how daft it was having lights on during the day .... how things have changed :LOL:. I had a 480ES which I loved and that had the same arrangement, 21W running lights, then went down to 6W I think it was when you put the headlamps (pop-up) on. Basically they were fitted with the same bulb as the rear stop/tail lights.
  9. alanclarkeau
    7,045
    7,593
    Yes, remember the 480s - but never saw one. They never came here.
    Harters likes this.
  10. peter
    peter Junior Member
    29
    gothenburg, sweden
    No. Running with parking light only at front is much less visible and thus more dangerous then using
    dimmed headlights. It all boils down to being seen by other as early as possible.
  11. peter
    peter Junior Member
    29
    gothenburg, sweden
    Yes, that IS the problem. If i turn the car off it should by itself turn off the lights, just like SAAB
    made it 1971.
  12. bisco
    52,431
    it should also shut down the 12v when it reaches a certain level, so it doesn't drain all the way. but after 20 years, nothing
  13. mr_guy_mann
    mr_guy_mann Senior Member
    4,098
    2,001
    NJ-USA
    Well, no manufacturer consistently implements headlight operation at all. My "high-tech gee-whiz" 06 Prius has manual headlight controls (no automatic mode). If left on they will turn off when you shut the car down. I haven't checked the configuration option menu about the DRLs.
    My 06 Corolla has daytime running lights with automatic function. So the DRLs (headlights only) are on all the time, unless it gets dark out, then it will turn parking and headlights on. If you manually turn the headlights on, they will stay on when you turn the car off. And you can't turn the DRL or auto function off.
    Then there's my wife's 08 scion xB. Manual headlights (you can change the configuration options to turn DRL on or off), but the headlights stay on when the car is turned off until you turn the switch off.
    Compare that to almost any (US-spec) Volvo made in the last 20+ years. On those the headlights and parking lights turn on with the ignition key-period. There's no point to having a headlight switch because it doesn't DO anything. (the only way to ever turn the lights off is to turn the car off). You might switch on the parking lights with the key off, but that will run the battery down in a few hours, so why do that?
  14. peter
    peter Junior Member
    29
    gothenburg, sweden
    I aggree, the Volvo way is the way to do this.
    There was a few years when only SAAB did it this way, but in the end volvo got the light(!) with the
    introduction of 760.
  15. alanclarkeau
    7,045
    7,593
    VOLVO 244 actually. My '80 did. But by the 940, it was gone.
