Repairing Gen 3 Armrests
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by synth, Nov 11, 2017.
  1. synth
    synth Junior Member
    Hey has anyone ever had success repairing the armrest on a Gen 3 Prius? Specifically, I have a 2010 where all the cushioned armrest plastic support clip (pretty weak construction) have broken so if you put any weight on them, they cave in. I am looking for a way to create support without having to replace the panel.
    With the panel removed, it appears the clips are not replaceable as they are part of the mold and the whole armrest insert does not directly overlap the panel mold except where the clips are at so a glue/adhesive does not seem like it would work.
    If you have any suggestions, please let me know.
    Thanks.
  2. Mendel Leisk
    38,737
    Post some pictures, the condition of the armrest, the clips you mention?
  3. synth
    synth Junior Member
    Thanks for taking the time to look. Attached are some photos.[​IMG]
    danlatu and Mendel Leisk like this.
  4. Mendel Leisk
    38,737
    Maybe you can mend with some fiberglass mesh reinforcement and liberal application of two-part epoxy. And I guess from here on you have to mend your elbow-resting ways, lol.
  5. synth
    synth Junior Member
    Thanks everyone for the thoughts.
    I was able to repair quite nicely using some epoxy gel on the nubs of the supports, and then after that had hardened to reinforce the edge with some fiberglass filler bridging the panel and the rest. Extremely solid now.
    And to be clear, it wasn't my arm-resting ways. I just don't think Toyota planned on the rests supporting the front paws of a 70lb lab who has his head out the window because he loves to go for drives in the car.
  6. Mendel Leisk
    38,737
    That's quite an image. (y)
