Repeated use/switching from "D" and "B" drive
Discussion in 'Prius c Main Forum' started by SwhitePC, Feb 11, 2014.
  1. SwhitePC
    SwhitePC Active Member
    495
    214
    ca
    Would repeated use/switching from "D" drive to "B" drive for regen braking pose any unwanted future wear-n-tear on the engine(s)/transmission/etc...???
    Thank you...I'm just wondering, since I've been lately switching a lot to B and so forth for regen braking in traffic/hills/etc...since my right hand is naturally on the shiftknob going back and forth from D and B every so often in a single trip
  2. css28
    css28 Senior Member
    1,566
    442
    Suburban Detroit
    It shouldn't cause any problems--but it wastes gas.
    B forces the car to spin up the engine to dissipate energy.
    It doesn't enhance regen.
    Mendel Leisk, ksstathead and xpcman like this.
  3. SwhitePC
    495
    214
    ca
    I was always under the impression that it spin up the engine more to dissipate energy and also in some of that energy goes into regen??? for the hv battery?
    So would it still be a waste of gas if the hv battery is running low to half??? and would it not also help sort of warm up the engine faster from cold starts in the day?
  4. css28
    css28 Senior Member
    1,566
    442
    Suburban Detroit
    It probably doesn't warm the engine up because it's not burning fuel--just acting like a big air pump to slow you down.
    Use the brakes! If you do it gently enough *all* of the slowing is from regen (without actually applying the pads to the discs until you're just about stopped).
  5. JimboPalmer
    12,470
    6,863
    Greenwood MS USA
  6. fuzzy1
    10,174
    With 'B', that energy is split between the hv battery and engine drag. With judicious use of the brake pedal, all of it is directed to the battery.
  7. SwhitePC
    495
    214
    ca
    aw, I see...I guess I'll have to kill my habit of putting my one hand on the shiftknob
    Stevie likes this.
  8. JimboPalmer
    12,470
    6,863
    Greenwood MS USA
    Not at all, just know you are hurting MPG. (but not the car)
  9. fuzzy1
    10,174
  10. cmstlist
    cmstlist Member
    183
    40
    Toronto, ON
    My former commute had a drop of almost 100 m along one particular road. The stop light before the downhill was almost at a flat point. I enjoyed accelerating using only EV, then slowly letting the hill take over, before beginning to brake the rest of the way down. I typically filled up the battery to the last bar by the time I hit the bottom, then coasted more than a km on EV through a slower speed industrial park before needing the gas again. Fellow drivers were unimpressed at my stop light behaviour though ;-)
    Nexus 5 ?
  11. Delta Flyer II
    Delta Flyer II Active Member
    547
    248
    69
    Glad I clicked on this post, I never knew that B wastes fuel…. Good to know… Prius Chat Community is always filled with tid bits of good and insightful info
  12. JimboPalmer
    12,470
    6,863
    Greenwood MS USA
    It can be used between 24 MPH and 7 MPH without wasting fuel, but why?
  13. koipond
    koipond Member
    198
    39
    I thought that "B" engaged the generator... not the ICE...
    SCH-I535 ?
  14. JimboPalmer
    12,470
    6,863
    Greenwood MS USA
    I am not sure we are responsible for what you thought. Below 24 MPH, it is possible B will not engage the ICE, but it is not a sure thing. Below 7 MPH it will be friction brakes, not the ICE or generator.
  15. fuzzy1
    10,174
    The generators are already engaged. Shifting to 'B' increases the generator power, but above 24 mph, only part of that goes to the battery, the rest goes to the ICE to be 'wasted' by spinning the engine (without burning gasoline).
    Judiciously pressing the brake pedal will produce exactly the same amount of generator power, but all of it will get sent to the battery. That is, provided the battery has room to take it, otherwise the car will still waste the excess in the ICE or engage the friction brake pads.
