Replace 12v Battery?
Discussion in 'Newbie Forum' started by Caleb2007, Jun 30, 2019.
  1. Caleb2007
    Caleb2007 Junior Member
    25
    Eastern WA
    Long story short... Randomly getting about 38mpg instead of my normal 46mpg in my 2007. Been doing trouble shooting and wondering if it could be my 12v. 12.1v initially, then I do the soft start thingy and I get 11.9v. I leave the lights and AC on for 5 minutes and it goes down to 9.9v. This indicate a weak battery? Perhaps the reason for my mpg dip? The HV battery is new with only 14000 miles on it.
  2. jb in NE
    jb in NE Senior Member
    2,233
    1,599
    Nebraska
    2018 Prius Prime
    Yes.
  3. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
  4. Caleb2007
    25
    Eastern WA
    I talked with a toyota dealer mechanic and he didn't seem to think it going down to 9.9 was an issue. "It's a small battery and is going to drain when used with no charge coming to it." Also, this morning I went through a car wash and while i was in neutral it started beeping at me and giving me the caution triangle telling me to put it in park so it could charge the battery. I got out of the car wash and put it in drive and it all went away. Is that normal?
  5. bisco
    52,849
    welcome!
    how many miles on her?
    how old is the 12v?
    is the battery really new, or remanufactured?
  6. Mendel Leisk
    42,345
    For a definitive test use an electronic load tester, either DIY with something like Solar BA5*, or check with automotive retailers selling batteries: they're likely to have a pro-level tester and will test for free. Dealership can test too, likely charge $50~100 though.
    * See Solar BA9 on amazon, a bit cheaper too. Hey, 9 has to be better than 5?
  7. Caleb2007
    25
    Eastern WA
    Bought the Prius about 3ish months ago. It had 95k on it, and it now has almost 98k. The previous owner had a local shop put a new HV battery in 2 years ago. I have no idea about the 12v battery. Dealership says about $350 for battery and install. I can install, I've already opened up the back all the way to do some troubleshooting myself. I just keep getting mixed answers about the 12v being the problem or not.
  8. Skibob
    Skibob Senior Member
    2,912
    1,505
    Northern California
    That beeping thing is normal. The Prius cannot charge the traction battery when the car is in neutral. Where you in a car wash that required you to be in neutral? Is so then you should basically turn off everything that uses power while you are in neutral, especially the AC. Just put the fan to a lower speed and suck it up for the 2 minutes. Turn off the radio and headlights if they are on too.
  9. Caleb2007
    25
    Eastern WA
    Bought the Prius about 3ish months ago. It had 95k on it, and it now has almost 98k. The previous owner had a local shop put a new HV battery in 2 years ago. I have no idea about the 12v battery. Dealership says about $350 for battery and install. However, I can install it if need be as I've already opened up the back all the way when I did my own troubleshooting. I just keep getting mixed answers about the 12v being the problem or not.
  10. Skibob
    2,912
    1,505
    Northern California
    Try cleaning your battery terminals and posts.
  11. bisco
    52,849
    you can't put a prius through a carwash that requires neutral, it drains the hybrid battery
  12. jb in NE
    2,233
    1,599
    Nebraska
    2018 Prius Prime
    I would pass on that good deal...
    Skibob likes this.
  13. fotomoto
    fotomoto Senior Member
    5,639
    3,815
    So. Texas
    Better define "local shop" and "new HV battery" because a lot people call a rebuilt/refurb HV battery new but it's not.
    edthefox5 and kenoarto like this.
  14. bisco
    52,849
    most techs don't know how to diagnose a 12v. that comes from years of trying to crank the engine, and determining by the sound if the battery is weak.
    tbh, you're voltage is sketchy, i would replace it.
  15. bisco
    52,849
    you need to get documentation of the 'new' hybrid battery. it could well be newly rebuilt and currently dying
    kenoarto likes this.
  16. Caleb2007
    25
    Eastern WA
    I have documentation of the receipt for the battery and installation, but I can't find where it says what kind/where the battery is from. It just says that one was installed for $2000 including tax and labor. But I do know that the previous owner told me that he didn't want the battery to be a used one for the same reasons you are all telling me to stay away from used batteries, so he specifically got a "new" one. Unfortunately I forgot to take a picture of the physical battery when I opened up the back to check the HV fan (which was not gunked, just dirty and air would still be able to flow through it).
  17. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,804
    2017 Prius c
    He is a fool and doesn't deserve the title "mechanic".
    10 volts is just a hair away from stone cold DEAD.
    amos, ishootstuff and kenoarto like this.
  18. fotomoto
    5,639
    3,815
    So. Texas
    New Toyota batteries were not $2k installed two years ago. Chances are very high it's aftermarket (used). Shops market them as new.
    kenoarto and jb in NE like this.
  19. Caleb2007
    25
    Eastern WA
    Wait. I just remembered I tried calling the number on the battery case when I had it all opened up. Calling it I found it was Dorman Products. So with a little more investigation I believe it must be what I found on their website. (I can't link it since I have yet to be on the forum for day and a mod has to continual approve all my posts.)
  20. Caleb2007
    25
    Eastern WA
    Well, it was being used without the engine running with AC and lights. (Again, I'm no mechanic, but a 12v is a small battery and is bound to lose power right?)
