Replace 12v battery?
Discussion in 'Gen 2 Prius Main Forum' started by lagreca, Jul 17, 2007.
  1. LeviSmith
    LeviSmith Member
    111
    NY
    Any chance they're like my 2003 was and if you have the parking brake on when you go to ready, the DRL's stay off until you take off the parking brake? That would take care of it once parked... If need be, you should be able to set the parking brake just a single notch and be able to drive without the DRL's coming on. (if it's the same as my 03'...)
    Levi
  2. BAllanJ
    BAllanJ Active Member
    667
    78
    Kingston Ontario
    I'll have to try that.... all I've tried before is seeing if they turn off when I set the parking brake.... thanks for the info.
