Replace 2005 base radio 51807 with 51824
Discussion in 'Gen 2 Prius Audio and Electronics' started by esoterikest, Jun 8, 2010.
  1. esoterikest
    esoterikest New Member
    Can I replace a 2005 base radio # 51807 with 2006 radio # 51824 ?
    I've searched and have not found any info on this specific swap.
  2. jelloslug
    jelloslug It buffed right out!
    813
    Greenville, SC
    Check the pinouts for both units. If they match it should work.
  3. jdenenberg
    jdenenberg EE Professor
    3,837
    1,828
    Trumbull, CT
    2020 Prius
    LE AWD-e
    I put a "Base" 2006 radio/CD in my 2004 with no problems. Call Steve at Plug In Hybrid Electric Vehicle PHEV (That's where I got the replacement unit) and he will confirm.
    JeffD
  4. esoterikest
    Thanks for responding guys but I really am hungry for the numbers on the face of the radios that can replace the 51807 radio. How about it?
  5. bedrock8x
    bedrock8x Senior Member
    1,483
    137
    Looks like they are exchangeable as they have the same connectors.
    Check the following listing on ebay and click on the picture of the back side.
    04-06 Prius Single Disc CD Radio 51807 OEM LKQ: eBay Motors (item 190397901464 end time Jun-17-10 03:30:29 PDT)
    2006-2009 Toyota Prius CD Player Radio OEM LKQ 51824: eBay Motors (item 200474867353 end time Jun-20-10 04:00:43 PDT)
  6. esoterikest
    Yup, looks like an easy job but does anyone have experience with this 51807 with 51824 swap to confirm it works?
  7. BillW
    BillW Junior Member
    DFW,TX
    Good luck, you've narrowed it down to a very specific swap. You may get to be the test pilot on this one!
  8. esoterikest
    Yup, got the radio today. I'll attack it this weekend and update. Wish me luck.
  9. BillW
    BillW Junior Member
    DFW,TX
    Good luck buddy, let us know how it works out!
  10. esoterikest
    Ok, done. It does not play MP3's on CD's but I hacked & spliced a 3.5mm headphone jack into it so I'm very happy. I followed another thread in this forum for this.
    I will record MP3 tracks at different bitrates and maybe that'll get it working. There are an additional 3 wires whose functions are unknown to me and maybe that has something to do with it.
    Weedle likes this.
  11. Oneaxepony
    Oneaxepony Junior Member
    60
    Northeast Ohio
    Nice work! I'm guessing the unit will play MP3s but you have to get the format just right. Read your Prius owners manual for some clues and also search for MP3s on PriusChat. It took me several tries burning MP3s before I got one the radio liked (format-wise). I assume the AUX works even though you didn't mention it.
  12. sktn77a
    sktn77a Member
    294
    NC
    Never had problems playing MP3s through an MP3-compatible player. I believe the decoding (MP3/CDA) takes place within the CD player and the outputs are analog. In which case, if you are getting output from CDA (a CD), you should be getting output from MP3 CDs also.
