1. The site is migrating to a new server this week, so there will likely be some downtime during that process. You can follow along here for updates.
Replace 2005 Cruise Control Switch
Discussion in 'Gen 2 Prius Audio and Electronics' started by Prius_Angie, Mar 27, 2018.
  1. Prius_Angie
    Prius_Angie Active Member
    245
    228
    Saint Louis
    P_20170420_141106.jpg OK as my 2005 Prius nears 260,000 miles several items have been in need of replacement, to include a non-functioning cruise control unit. I order a new $10 switch on Ebay and placed that onto the car. This is a pretty straight forward process.
    1. DISCONNECT BATTERY. First disconnect neg terminal to 12V battery. This will hedge off any inadvertent airbag deployments.
    2. ACCESS SIDE STEERING COLUMN AREA. With pry tool pop off plastic pieces to left/right side steering column. With a star pattern hex, I loosened both left/right side screws in order to release airbag access on steering.
    P_20171128_165010.jpg P_20171128_165022.jpg P_20171128_165142.jpg P_20171128_165153.jpg
    3. ACCESS STEERING WHEEL. The airbag can now flop up but no need to remove it nor the center steering nut.
    4. ACCESS CRUISE SWITCH. Now the 2 phillip head screws reveal themselves. Unscrew those and the electronic clip to release the cruise control unit altogether.
    5. SWAP OUT. Replace the old with the new. Reattach 2 phillip head screws.
    6. BUTTON UP IN REVERSE. Return the airbag and the side panels.
    7. Whoala!
    8. *** OLD INTERNALS
    P_20171105_151339.jpg P_20171105_151537.jpg P_20171105_151639.jpg P_20171105_151655.jpg
    NOLA_Akita and Another like this.
  2. Pat562
    Pat562 Junior Member
    Funny, but I have a 2005 Prius with about 260,000 miles and it appears that my Cruise Control Switch went bad.
    -Is it really that easy to replace the switch, and I saw another post that said must also replace break switch or it will not work. Did you replace both switches or did it work with just replacing cruise control switch?
    kenoarto likes this.
  3. Prius_Angie
    245
    228
    Saint Louis
    I sold that brown 005 Prius a year ago.
    it CRUISED good since the simple procedure for the new buyer.
    Do as i did...
    - unplug the 12V battery
    - openup the steering wheel safely
    - unplug
    - swapout
    - button up
    - whoaala
    good luck
  4. Epiphany2000
    Epiphany2000 Member
    126
    40
    San Francisco Bay Area, CA
    Thank you for the excellent post. With your help, I was able to swap out my broken cruise control switch in ~15 minutes. I also bought a cheap non-OEM switch, although not quite as good of a deal as you got ($17.63 out the door from Amazon). I don't remember how much a genuine OEM switch would have cost, but it was definitely much more expensive.
    I was willing to pay a nominal fee to get the switched replaced professionally. Luscious Garage quoted me a whopping $376.66 for the job. Needless to say, I declined their offer.
    I've got a little under 170,000 miles on my car. This is a bit early for a switch failure (according to the above posts), but I use my cruise control very frequently, so it makes sense.
    Thanks again for the helpful post.
    Prius_Angie likes this.
  5. Prius_Angie
    245
    228
    Saint Louis
    GLAD it worked out for you
    such an easy procedure
    perhaps just as easy & fast as changing oil
    key is to remove power 12V or risk poss steering column airbag employment
    LOVE those 2nd gens
    they are so impervious to abuses--
    what ever you throw at 'em---keeps on ticking
  6. Another
    Another Senior Member
    1,802
    507
    Naples, Florida
    Great post.
    I use my cruise control a lot. I often wondered how complicated it will be when, not if, I have to replace the switch.
  7. Another
    1,802
    507
    Naples, Florida
    It looks like the OEM switch on Amazon is $92.
    Do you have the link for the one you used?
  8. Prius_Angie
    245
    228
    Saint Louis
    Its a pretty easy & quik procedure. GL
Loading...
