replace all four brakes pads and rotors
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by jmann, May 29, 2021.
  1. Mdv55
    Mdv55 Active Member
    246
    181
    Boston
    For how long? 100k+ intervals on brakes with these cars. My guess is they'll be well below spec before the 2nd interval is done. Maybe not in the desert and where people go 60-70k a year and barely touch them. In New England they're gonna be trashed. Not the greatest pic, but those are 2 1/2 years old. I doubt most people are doing the math to see how much wear came off the rotors to see if they're more then half worn. Above minimum? Send it.......
    I'd rather just change them once and have them go the distance then change them out halfway. The less downtime the better.
  2. ChapmanF
    19,055
    Yeah, when they've got chunks out, that's not really spec. :)
  3. Mdv55
    Mdv55 Active Member
    246
    181
    Boston
    I get what you're saying, but those are less then 3 years old. I have a hard time believing people still have rotors in spec to make 2 pad change intervals in the majority of the country.
  4. Mendel Leisk
    42,376
    Boston Mass is salt central?
  5. Mdv55
    Mdv55 Active Member
    246
    181
    Boston
    They love liquid salt here. It's killing things fast. I had to drill out a caliper pin last year :(
    Absolutely in the rust belt.
  6. Mendel Leisk
    42,376
    Around here our local small mall is terrible, maybe managed by a litigious lawyer: there was still plenty of salt in blazing-sun spring.
  7. jmann
    jmann Member
    201
    30
    Cleveland, OH
    Hey guys! job done. Definitely not rocket science. Shout out to O'reilly auto parts who had a guy that helped me collect all of the right tools for the job.
    Question: I was left after install with 2 stainless sheet metal shims per side in the front that didn't fit back on over the new pads (the tabs didn't fit on the new pads). Is this correct? Should I care?
    On the back, all three stainless shims per side fit back on over the new pads. There were some extra black sheet metal parts, but I assume they were part of the pads and should be discarded.
    This is what I put on the car: More Information for POWER STOP KOE5871
    The new brake pads say "include rubberized stainless shims pre-installed"
    This was so straightforward once I figured out all of the tricks I didn't even stop to take pictures. I ran into the problem where the wheels were stuck to the rotors (and they were just rotated three weeks ago, so that is how fast this stuff rusts together in the north). I also didn't understand how much I actually had to twist in the rear pistons. It takes a lot of twisting. But, hey, I could do this again in like two hours.
    I also had to buy a breaker bar because I'm just not strong enough to get this stuff off with normal tools or hold a torque wrench in place. I can probably do more one legged squats --on a bosu ball-- than anyone else here, but I can't do a single push-up.
    #27 jmann, Jun 6, 2021
    sLick415 and ASRDogman like this.
  8. jmann
    jmann Member
    201
    30
    Cleveland, OH
    delete
    #28 jmann, Jun 6, 2021
  9. mr_guy_mann
    mr_guy_mann Senior Member
    4,120
    2,018
    NJ-USA
    I find it helpful to clean and lube the threads in the rotor "hat" before trying to use the bolt. If the rotor doesn't want to move with about 20 ft/lbs of torque on the removal bolt, then use a large hammer to hit the edge of the disc. Spin the rotor 180* and hit it again. Put a little more torque on the bolt and repeat. Then scrape all the rust off the hub and put antiseize on before fittong the new rotor.
    Before you rotate the caliper pistons back, gently pull the piston boot slightly away from the piston - you don't want it to stick in its groove. I use a small bit of silicone spray to help it along once I've unstuck it.
    Ed Beaty likes this.
  10. sLick415
    sLick415 Member
    214
    55
    San Francisco, CA
    You're fine. The purpose of those shims is to help prevent vibration noises. Some pads come with them, some don't. Depends on the design.
    Congrats on your first brake job!
  11. jmann
    jmann Member
    201
    30
    Cleveland, OH
    Thanks. I get to be proud of this one for the next week. But seriously, it was easy. I can't believe the dealer quoted me $1000 for 4 sets brake pads and two rotors. (rotors are cheap. I replaced them all) -- something that should have coasted $150 for premium parts and two hours of labor. while this brake job probably took me 4+ hours, the next one will take 2.
    sLick415 likes this.
  12. Solman636
    Solman636 Member
    99
    37
    Florida Panhandle
    Should I change the rotors?? My 08 has 160,000 miles. The rotors looked fine actually although I did not measure them, BUT I just put on new pads yesterday and got to thinking maybe new rotors a good idea now and then can forget about the front brakes for another 150,000 miles by which time I will be 104 years old with my current usage rate.
  13. ASRDogman
    ASRDogman Senior Member
    8,070
    4,092
    As long as there is not a lip on the outer edge, and there is no pulsing while braking,
    you should be fine.
