Replace both struts AND shocks?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by hearsay, Dec 10, 2015.
  1. Patrick Wong
    18,210
    6,516
    I don't think the bounce test is effective on the Prius. I have tried that on my vehicles, and even though I can't force excessive bounce with that test, I've found the worn struts/shocks are pretty bad after removal and inspection. My basis for saying "pretty bad" is determining the rate at which the strut rod will expand out of the body once compressed, and comparing to new.
  2. valde3
    valde3 Senior Member
    2,002
    750
    Finland
    Bounce test doesn’t really work on any newer car. By the time they would fail the bounce test they would be almost undrivable.
  3. timmyjane
    timmyjane Junior Member
    87
    SC
    Thanks. Ill just go ahead and put that on the list of things to do.
  4. Rph74
    Rph74 Active Member
    292
    234
    Springfield,MO
    Clay- I did exactly as you did, ordered the front strut/spring assembly from Rockauto-big time saver (since I'm very much an amateur).
    For the rears I ordered KYB shocks from rock auto and ordered new Springs from Toyota. There was a noticeable rear height difference when the spring change was done.
  5. Rph74
    Rph74 Active Member
    292
    234
    Springfield,MO
    I would add that replacing the coil springs would add zero extra labor while doing the struts, so if you're going to do it, now is the time!
  6. Clay Chapman
    Clay Chapman Junior Member
    Brooklyn, NY
    Labor for all four shocks/struts came to $280 so that's $550 total for full Monroe assembly kit in front 172357 and 172358, and strut replacement in back 72394 (2). They also said to wait 150 miles or so before doing alignment fwiw. (They don't do it there). Rides much much better now. Mechanic confirmed they were original parts removed, replaced after 130,000 miles. And it was by then a pretty rough ride even though it didn't bounce. So idk about that push down test. I just know it rides better now and doesn't make same noise with bumps.
  7. Clay Chapman
    Brooklyn, NY
    Rph
    rph74. What you're saying makes a lot of sense I should have done that!! They said they looked OK but for just the price of the springs I'm sure it would've made a lot more sense to go ahead and get new ones. How much did you get the two rear springs for?
  8. Rph74
    Rph74 Active Member
    292
    234
    Springfield,MO
    I bought the springs from Toyota of Dallas. I just looked, and they have springs listed at $54.88 each.
  9. WhoDat!
    WhoDat! New Member
    Anyone of you members recall a chat where there's a mechanic in El Monte, CA. that replaces the strut, and coil, for a good price? Or, a good mechanic in the Chino, CA. who works on Prius? Thank you!
