Replace brake acutator and skid control ECU or not?
Discussion in 'Gen 2 Prius Main Forum' started by lymankj, Oct 14, 2018.
Tags:
  1. lymankj
    lymankj New Member
    Honolulu
    Hi All,
    I've had a Prius 2nd with 120k miles on it for 6 months, purchased for $2,500.
    Last month the car dash lit up and the rear right wheel locked in place. I towed it to the dealer repair shop for an assessment. They responded with codes C1256 and C1391 (Faulty brake actuator assembly and faulty skid control ECU assembly) as well as a few other codes that may have been longstanding but not fatal (C1241 Low battery positive voltage; C1300 ABS ECU Malfunction; C1343 Hydraulic System RR; C1344 Hydraulic System RL; C1391 Abnormal Leak FO ACC press).
    The dealer shop quoted ~$5,500 to replace the ECU and brake assembly and recommended not proceeding with the repair.
    I found another mechanic in town who is recommended for hybrid repairs. He said he can do the repairs but has not given a quote. He also said he could use used/salvage parts but would not offer a warranty. It appears that the brake actuator is ~$300 salvage and the ECU about $50 on Ebay.
    Is this a good idea? Is it worth trying a repair with salvage parts for less or with full-price repairs with an independent mechanic?
    Thanks!
  2. Rph74
    Rph74 Active Member
    292
    234
    Springfield,MO
    How much in labor?
    Personally I’m a gambler, and I would give the salvage parts a shot.
    Skibob likes this.
  3. Skibob
    Skibob Senior Member
    2,912
    1,496
    Northern California
    Check the battery voltage yourself. These cars are well documented for having odd problems when the 12v battery is old/ low charge.
  4. davecook89t
    davecook89t Senior Member
    1,057
    789
    Washington State, Florida
    Four Touring
    The car has relatively few miles, but is now almost 15 years old if the information in your profile is correct. Before you spend anything, I would want to know the condition of the HV battery. More than likely it has been replaced since it would unusual for this type of battery to last that long, especially in your warm climate. I would guess that the replacement was not a new battery from Toyota if you were able to buy the car for such a low price. If it turns out that the battery had been salvaged from a much newer car and is likely to last for several years, it would be worth spending money to replace the braking system, but I would probably go with the salvaged parts and hire an independent mechanic. If your replacement battery was one that had been rebuilt from older modules (as has so often been the case with others posting here), it is likely that the previous owner knew it would not last much longer and was willing to let the car go for a low price. In that case, you will shortly have an even bigger problem than the brake actuator and may want to reconsider spending any more money on the car at all.
  5. lymankj
    lymankj New Member
    Honolulu
    Thanks for the advice!
    The previous owner is a friend, basically inherited the vehicle (over my objection) due to unforeseen events.
    I will find out the condition of the main battery, but I believe that the 12v battery has been replaced before under warranty.
    There's multiple slightly newer Prius on CL here for from $3.5 to $5k, but I'm beginning to realize that these could also have mysterious and expensive problems....
    davecook89t likes this.
  6. davecook89t
    1,057
    789
    Four Touring
    Overall the Prius is a very reliable car, but it's true that when something breaks it is likely to need an expensive part, particularly if you need to buy it from the dealer. If you can salvage a part from a reliable source, however, it becomes much less expensive, and if you are brave enough to attempt some of the repairs as DIY, you can save even more. Now that you've explained that you know some of the history of this car, I would be much more inclined to recommend that you make the effort to search out the braking system parts you need from local salvage yards. With so few miles and a known history (hopefully your friend has kept up on all required maintenance), it might even be worthwhile to invest in a new HV battery if the current one fails at some point in the future. A smaller worthwhile investment would be a scan tool such as this,
    , which combined with the Torque app on your phone, would allow you to monitor the car's hybrid system and possibly get ahead of some needed future repairs. Another alternative is this device,
    , which can be used with Toyota's Techstream program on a Windows laptop for a more complete analysis of the systems on your car.
  7. Phildo
    Phildo Active Member
    137
    107
    Perth, Western Australia
    i-Tech
    Toyota's pricing makes mafia people jealous.
    ABS modules wear out on the hybrids (ie Prius and Camry hybrid).
    If you don't trust a secondhand part then there will be somewhere that is reconditioning them.
    Find a taxi workshop - they'll be changing ABS modules on hybrids regularly, and will have figured out the cheapest option.
    You'll want to get the job done by someone who's done it before (eg taxi workshop) as it needs Techstream (or another computer option) to bleed the brake fluid.
    This clip shows how the job is done - it's not particularly time consuming or complicated for any mechanic with Prius experience.
    Skibob and davecook89t like this.
  8. lymankj
    lymankj New Member
    Honolulu
    Thank you all for the very helpful posts!
    I got a quote from an independent mechanic (also the island's hybrid expert) to replace the 12v battery for ~$250 (which has failed while the car sat for a month, or possibly before) and to replace the brake actuator assembly for $900 in labor with a refurbished part I'll have to order off EBay.
    Is this the part number (from the mechanic's invoice) "44050-47091 BRAKE ACTUATOR-S"?
    I can't find anything on Ebay with that specific number. Can't post a link here but they are listed as something like
    2004-2009 TOYOTA PRIUS ABS ANTI-LOCK BRAKE PUMP ACTUATOR ASSEMBLY 05 06 07 08
    for around $250. However, the mechanic says that the problem may be more complicated than just this unit, and may require replacing additional components (like the ECU). Is it worth it to proceed?
    Thanks!
  9. davecook89t
    1,057
    789
    Four Touring
    I think I'm back on the fence as to whether you should spend any more money on this car, even with the ability to find some information about its maintenance history through knowing the previous owner. I would absolutely want for either you or your mechanic to have a working knowledge of Techstream and access to the online repair manual at techinfo.toyota.com before spending even as little as $250 for the new 12V. If you are careful, you can connect a borrowed fully-charged 12V to the jump points under the hood before replacing the battery you have now. This will allow you to more precisely evaluate which components have failed using Techstream and the repair manual. Then you can make better decisions about whether to proceed or not.
  10. Phildo
    137
    107
    i-Tech
    Wow.
    Your hybrid expert is doing rather well.
    If you have a daughter then get her to marry him.
    Their kids will be able to go to the best private school on the island.
    How to replace the ABS module:
    $900 labour for that is insane.
    TomB985 likes this.
  11. Teresa Y Kirkpatrick
    Huntsville, AL
    I was just diagnosed needing an ABS Actuator and Skid Control Module, and was quoted the repair estimate to be $6000+! The labor was $1400!!! I am still in shock!!!!!!
  12. ChapmanF
    15,445
    There's a thread specific to Teresa's issue over here.
