Replace coil packs when replacing spark plugs?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Frogerelli, Apr 14, 2022.
  1. Frogerelli
    Frogerelli Junior Member
    Fort Smith, Arkansas
    2010 with 98,000 miles. I have the c1391 code for brake actuator failure so it seems like a good opportunity to replace the spark plugs too. Is it advised to change the coil packs at the same time?
  2. Leadfoot J. McCoalroller
    8,147
    7,647
    Pennsylvania
    2018 Prius c
    not unless you have a failure indication. They are meant to last a long time and many cars go to the crusher with the factory set still in.
    So absent any misfire codes or suspiciously low fuel economy, keep going with what you've got.
    Pdaddy and Frogerelli like this.
  3. tankyuong
    tankyuong Senior Member
    1,555
    662
    Central MO
    Mine still running strong at 200k miles
    Frogerelli and Pdaddy like this.
  4. PriusCamper
    PriusCamper Senior Member
    13,055
    5,305
    Pacific Northwest, USA
    Do you always fix stuff that ain't broke?
  5. Frogerelli
    I do. It's called "maintenance", just like with oil, tires, spark plugs and other things. In this case, my experience with coil packs is that on my '99 Volvo all failed, one at a time, within about 5,000 miles at 140k. And in that case I didn't need to remove any cowling or wiper assembly to access them.
