Replace Engine or Junk Car?
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by TLL, Nov 26, 2016.
  1. TLL
    TLL New Member
    I've had that suspicion, since a salesman was on my husband about trading our car in for a new one. I didn't say anything at the time, but was thinking that if what their service department said about the engine was true, why would I ever want another Toyota? It's what brought me to "priuschat". Thank you for all your comments and advice!
    Thank you! I thought the $6,000 quote sounded outrageous. Which is what they also told me the car would be worth, if I traded it in. I'm beginning to think they needed to meet their sales quota for the month, and were trying to get me to buy a new vehicle...
    I'm now thinking they didn't look much "into it" at all. I have a lot of questions for them now, when I go to pick up the car on Monday.
    Don't know the actual fault code, but will ask when I go back on Monday, to get he car.
    Incompetence of the service department is what stopped me from going to the original dealership I purchased the car at. Couple of examples: After getting home from a regular maintenance service, my car would not start at all, was going to have it towed to dealership, when a neighbor looked under hood and noticed a couple of hoses were not even connected. We assume they weren't reconnected properly, and came loose during drive. When I called the service advisor, he said there was no way one of his guys would've done that. Numerous times, simple things like a headlight/or interior light out, would still not be resolved after service was performed (according to the check list, they're supposed to look for that!) so I would have to specifically point out any little thing I needed done, or it would get overlooked. And the final straw, was when I called to make a service appointment, and they could not find a record of my car, even after giving them the VIN number... I told the girl in the phone, "I purchased the car from you, and you can't even find it in your system?" She just said, "Yeah, that's weird." I never went back, and now drive an hour out of my way to the dealership in the next town. This new dealership also missed a burnt-out running light. I think I'm done with Toyota after this. Just not happy with the service in my area.
    #21 TLL, Nov 26, 2016
    RCO and Merkey like this.
  2. Mendel Leisk
    42,355
    Maybe a compression test?
    TLL likes this.
  3. William Redoubt
    William Redoubt Senior Member
    1,228
    1,174
    Coronado Island, California
    Ask for a full written report of what was done and what the diagnosis is. And then report here.
    TLL likes this.
  4. TLL
    TLL New Member
    I will. Thank you.
  5. TinyTim
    TinyTim Active Member
    418
    243
    Seattle
    Will the car run at all? Will the engine turnover at all?
    TLL likes this.
  6. ozmatt
    ozmatt Active Member
    637
    263
    Australia
    chuck a bottle of "chemical seal up" in it and drive to the stealership you bought it from and trade it in :)
    RCO and William Redoubt like this.
  7. TLL
    TLL New Member
    Yes, car drove normal, but engine light was on.
  8. TLL
    TLL New Member
    Lol, I had to Google what that was. Sounds too good to be true!
    RCO likes this.
  9. ozmatt
    637
    263
    Australia
    not overheating yet? you absolutely need to know exactly which diagnostic code they extracted from the car before you go any further
  10. bhtooefr
    bhtooefr Senior Member
    1,396
    1,489
    Newark, OH, USA
    Do not put in any additives like a head gasket sealer unless you're ditching the car immediately, and even then, it's dishonest to use those.
    (It's a good way to clog coolant passages.)
    RCO, William Redoubt and Mendel Leisk like this.
  11. fotomoto
    fotomoto Senior Member
    5,639
    3,815
    So. Texas
    Agreed. Engine oil with a milky look is another clue that coolant is getting into the engine where it shouldn't be; however, water vapor is also a byproduct of the combustion process and can be found in any oil that doesn't get hot enough to boil off. It's the amount that's important.
  12. Mendel Leisk
    42,355
    We've had the latter (years back, other car), no coolant leak, just insufficient warm up, condensation in the oil. An extended drive would clear it up, if it was condensation.
  13. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,801
    Undisclosed Location
    Yes. Toyota has a great reputation for building reliable vehicles.
    NO. I wouldn't recommend NOT changing your oil, or changing it in 30,000-40,000 mile increments.- I wouldn't even bring it up. Maybe some people are that neglectful....but it's NOT a good idea, synthetic oil or otherwise. Why risk your vehicle to stretch out beyond all recommendation, a maintenance routine that costs less than $50?
    Toyota does have a well earned reputation for quality vehicles. BUT...machines are unaware of that reputation.
    My advice....AT LEAST....change your oil as recommended.
    If you want to gamble?
    Change more often. Not less often.
    To the OP?
    Reading your original post?
    Well first you have to get full definition of the problem.
    BUT...if you really are stuck needing a new engine?
    On a vehicle you bought new, that is barely 5 years old, that has been well maintained in all other regards?
    I might seriously consider making the investment.
    Still a lot cheaper than buying a new vehicle. And expectation would be that you could get a whole lot more life out of the vehicle.
    Good Luck.
  14. mikefocke
    4,081
    1,863
    Sanford, NC
    I come from a world of another make where a used 70k mile engine would cost more installed than the car was worth running fine. And a completely remanufactured engine with improved parts could cost 4 to 6 times the worth of the car even without an engine failure! So all disasters are relative. Not that that make it any easier if you are one of the few who have a failure.
    And even remanufactured engines can be trouble. The only time I ever bought one I only got 1,200 miles out of it before it was back in the shop for another replacement. Fortunately a good warranty and no hassle. That was a Mitsubishi engine in a Dodge mini-van.
    I'd start out with the assumption that dealers seldom go inside engines. They replace them. I'd go looking for a repair shop that specializes in Prius cars and wagons and let them quote you a replacement engine that they source and guarantee. Not like a new car warranty nor even like a remanufactured engine. But some 30-90 day guarantee. Engines from wrecks become available every day and even a car as uncommon as a v will have lots at the wrecked cars being sold for salvage at any given time. (There are 61 available today at this site. Some will be sold to a shop that parts them out and thus engines are available. Reputation of the seller and installer is everything.)
    RCO likes this.
  15. rdgrimes
    rdgrimes Senior Member
    1,740
    448
    New Mexico, USA
    2018 Prius Prime
    At this point there's no reason the think the OP needs anything more than a head gasket, if that.
    RCO, Bluegrassman and William Redoubt like this.
  16. Mendel Leisk
    42,355
    Yes but will any mechanic do that for reasonable price? Not a rhetorical question, just wondering. Luscious Garage style business?
    I've attached the relevant Repair Manual pages. Step 1, removal of camshaft housing sub-assembly, is a whole story unto itself. Here's an exploded view too:
    #36 Mendel Leisk, Nov 27, 2016
  17. ozmatt
    637
    263
    Australia
    absolutely its not a quad cam 400 valve twin turbo race engine! just change the gasket how hard could it be for any competent mechanic.
    Never use the words "honest" and "car dealer" in the same line lol.. Seal-up Is nice to use for a test, wont "clog" anything more than its supposed to (the crack) if your radiator has restricted flow and was on the way out anyway then it might clog otherwise its not a problem (if used properly) ..wont work very well on blown head gasket but very useful if testing for slight cracks in alloy heads and can patch head cracks over for years the problem with this stuff is people don't use it properly (drain coolant ad fresh water, install sealer drive for a full day or 100miles, re-flush water TWICE then re-ad coolant) I have used it more times than I care to remember and never had a problem other than what i started with when used properly! other than maybe a weak radiator crapping out, it either fixes the problem or doesn't! but never made anything "worse" well not for me anyway. Ohh and turn the heater off you don't want it going in there!
    Not "sure" but don't think you have to totally strip the valve assembly as above to remove the full assembly. If the mechanic couldn't remove the cam housing in an hour or two I wouldn't want them changing my whole engine that's for sure.
    RCO likes this.
  18. ILuvMyPriusToo
    ILuvMyPriusToo Senior Member
    780
    518
    Outside Philly, PA
    2024 Prius Prime
    I had a head gasket replaced on my Subaru Forester, but then again they have a lot of experience doing those . . . :(
    I'm not even going to start with the dealer horror stories . . . :mad:
  19. bhtooefr
    1,396
    1,489
    Newark, OH, USA
    One thing with a Forester is that there's two head gaskets, and the engine positioning is such that... can you even get the heads off without removing the powertrain entirely?
    You could almost certainly do a Prius head gasket in the car, I suspect.
  20. ILuvMyPriusToo
    780
    518
    Outside Philly, PA
    2024 Prius Prime
    I was able to get the shop to do one side without pulling the Forester's engine. Had they done both, they said the time savings on the job would justify taking it out for better access.
