Replace Engine or Junk Car?
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by TLL, Nov 26, 2016.
  1. Dat Boi
    Dat Boi Junior Member
    36
    Alton, Illinois
    That's so odd, i've never heard of the Prii to have headgasket problems!
    I am @ 301k on my Gen 2, and it doesn't burn or leak any coolant, nor do any fluids mix.
    Merkey likes this.
  2. bhtooefr
    bhtooefr Senior Member
    1,396
    1,489
    Newark, OH, USA
    I've heard a few reports of Gen 3s doing it here and there, on these forums. (The Prius v basically being a Gen 3, after all.)
    Interestingly, looks like the head gasket was revised in October 2011 (which would be partway through MY2012)... wonder if they had a design flaw in the head gasket.
  3. hellonearth
    hellonearth Junior Member
    35
    Any update? Hopefully there was a cheaper fix from a second opinion
  4. William Redoubt
    William Redoubt Senior Member
    1,228
    1,174
    Coronado Island, California
    Well, there's your issue: Mitsubishi. Crapcans. Every last one. Hook a Mitsubishi engine to a Dodge transmission for a total disaster: the Caravan. That's if you can get the starter to turn the car over. Another famous component failure by Dodge.
  5. Prodigyplace
    12,717
    11,849
    Central Virginia
    How the mighty have fallen. Anybody remember the Dodge & Plymouth 225 slant six engines that lasted forever?
  6. Rmay635703
    Rmay635703 Senior Member
    2,704
    1,729
    Somewhere in Wisconsin
    2013 Chevy Volt
    Unless you drive through snow it melted and then the things missed terrible ;)
  7. William Redoubt
    1,228
    1,174
    Yes. But they still had starter motor problems, if I remember correctly.
  8. Bill the Engineer
    1,048
    2,278
    467
    At the beach in Delaware...
  9. Prodigyplace
    12,717
    11,849
    Central Virginia
    Bill the Engineer likes this.
  10. Bill the Engineer
    1,048
    2,278
    467
    Yes, plus some extra parts that I needed.
    Bill the Engineer
    Prodigyplace likes this.
  11. bisco
    52,863
    we had a 75? dodge with a slant six. can't even remember how many miles. i did a valve job and she was good as new. brakes were another story.(n)
  12. Prodigyplace
    12,717
    11,849
    Central Virginia
    I had a 75 Duster. I also had a 72 Dart that has a front torsion bar rust out of the frame during a long trip. It is not easy driving with no suspension on one front wheel. :eek:
    RCO and William Redoubt like this.
  13. cipsaz187
    cipsaz187 Member
    150
    43
    Don't do at the dealer. The dealer doesn't care about your car. They're part changers after all. Most of the time they don't even diagnose the problem right. Let alone working on the engine. I would only do it at the dealer if Toyota would cover the cost or at least some of it.
    After that being said, you need to find a decent repair shop who can diagnose the issue correctly and move it from there.
  14. Socal2012PriusOwner
    Socal2012PriusOwner New Member
    Southern California
    I just had my check engine light come on last week. Was starting a little rough. Blown (warped) head gasket. Coolant leaking into 1st and 2nd cylinders. 168k miles.
    A friend of mine had the same thing happen to him about a month ago with his 2013 Prius. 155k on that one.
    This is appearing to be a defect that's becoming more apparent as the vehicles age.
    Got a quote yesterday for engine replacement at close to $4k. Not sure if it's worth it. Thoughts?
  15. ILuvMyPriusToo
    ILuvMyPriusToo Senior Member
    780
    518
    Outside Philly, PA
    2024 Prius Prime
    If the rest of the car is in great shape (no rust in SoCal?), 4K for a good engine sounds like a good deal. Is that engine lightly used or have a lot of miles? Will they rebuild/replace the HG or just drop it in? Good luck!
  16. Prodigyplace
    12,717
    11,849
    Central Virginia
    Is this a Prius v? It is posted in the Prius v forum, not the Generation 3 one.
  17. Borninblue
    Borninblue Active Member
    233
    158
    Cleveland, Ohio
    These blown heads at 140-180,000 have CLOGGED EGR cooler written all over it. Take heed in this project/advice. At
    127,000 mine was completely clogged. The EGR tube itself wasn’t too bad. Unfortunately if you don’t clean them out you are riding in a time bomb waiting to blow the gasket. It’s a pain to do but less of a pain dealing with scrapping the car or new engine. Save the cash for the new traction battery and keep on rollin.
  18. bostonbruins8703
    bostonbruins8703 Active Member
    178
    101
    Brewster, Ma
    2024 Prius Prime
    XSE
    My V has 130,000 miles on it. I did the full EGR cleaning,manifold, throttle body, replaced the PVC and installed an oil catch can. My estimation, it was about 10% clogged. I intend to keep my car until "the wheels fall off" or until its at least paid and I can get a newer model within my budget. All I can say is that I'm glad I got the cleaning done and installed the oil catch can.
    Raytheeagle and Mendel Leisk like this.
  19. Mendel Leisk
    42,355
    Just repeating what I've read/heard here, but my understanding is: as the EGR clogs, the combustion chamber temperatures climb, dramatically. The engineers designed this car to depend on functional EGR. Too bad they didn't do a better job designing the EGR. :mad:
    So far, Toyota doesn't want to know about it. The've paid lip service up here in Canada (and I assume the same is happening in the States) with a Warranty Enhancement Program*, that's too-little-too-late, laced with expressions like:
    "While the majority of vehicles will not experience this condition"
    Italicized and underline, just like the above.
    * Toyota Canada reference: SOSH-W11-1A, May 2017
    I see if you search for that reference number, my scans of the notice show up, like a rash, lol.
