Replace Front Caliper Guide Pin Bushing
Discussion in 'Gen 3 Prius Main Forum' started by Frontporch, Sep 9, 2025.
  1. Frontporch
    Frontporch Active Member
    549
    128
    Nj
    I just replaced my front brake pads last night and was surprised how sticky the caliper guide pins were. Despite that the wear on the pads was pretty even.
    My question is has anyone replaced the lower guide pin bushing? I had a heck of a time even after lubing the guide pin and bushing getting that to install and.. when installed, it moves but not easily at all.
    I have read that the OEM pin is pretty tight. Also I remember that some bushings can swell with certain lubricants...
    Any guidance would be appreciated.
  2. Mendel Leisk
    42,330
    What lubricant did you use, and have you used it on those pins before?
  3. Tombukt2
    Tombukt2 Senior Member
    13,848
    2,515
    Durham NC
    Yeah I have some packs of brand new ones laying on the floor you can buy them everywhere including your local parts store for the Toyota . Or you can keep cleaning and flushing and spraying and brushing and cleaning or spend 8 bucks .
  4. ASRDogman
    ASRDogman Senior Member
    8,057
    4,085
    Did you clean out the rubber bushing? Cleaning the pin alone is not enough.
    And then use the brake lube. It should be a snug fit and have resistance moving in and out.
    Frontporch likes this.
  5. Frontporch
    549
    128
    Nj
    Thanks for the replies.
    I cleaned the pins but need to do a better job of cleaning the caliper mounting bracket cavities. I plan on removing the bracket, removing the pins and taking off the rubber caliper accordian seals and brake cleaning and wiping down inside the mounting bracket. I called Toyota and they sell the bushings for about $3 each, so have a pair of those on the way.
    ASRDogman likes this.
  6. Frontporch
    549
    128
    Nj
    I have not serviced the brakes before. Car is a 2012 and i have had for less than a year. I usually coat those slides with a synthetic black brake grease. There could be better options. Any suggestions?
  7. Mendel Leisk
    42,330
    I use Sil-Glyde Brake Lubricant on the pins, never seen any swelling of the rubber rings, on the pins that have them. There are various other acceptable lubes. There is a Toyota spec'd lube for those, a little hard to find and/or pricey. Someone may be along shortly with more detail on that.
  8. Mendel Leisk
    42,330
    I think Eric O. (South Main Auto) is using this. I've never paused the video to try to check, but there's mention here.
    Danno5060 and Frontporch like this.
  9. ChapmanF
    19,009
    Yes, here's the "more detail", which Mendel does already know: Toyota specifies a grease that is glycol based and thickened with lithium soap. It is red; it comes in tubes that say "rubber grease"; if you want to buy a whole tube the P/N is 08887-01206, and you don't need to buy a tube if you buy a caliper rebuild rubber kit from Toyota because a small packet of the right grease is included in that kit. It is one of three different greases Toyota specifies for different parts of the brakes.
    There it is, that's the more detail.
    What's weird is whenever a different topic—transmission fluid—comes up, we can rely on Mendel to give the information about the manufacturer-spec'd ATF-WS fluid. Those threads also discuss other products people might personally use and like, which is great, but readers do have a right to be informed what the manufacturer's spec is, so they can make their own informed decisions. Mendel does understand that, as so many of those transmission threads clearly show.
    I wonder if it would be fun for me to post in each new transmission thread "there is a Toyota-spec'd lube for this; someone may be along shortly with more detail on that" and then wait to see if Mendel ends up posting the "more detail" that I left out even though I also knew it. I could have the fun of wasting someone's time! I haven't tried it! Maybe that's why I just don't get how much fun it is.
  10. Mendel Leisk
    42,330
    I'll be there. :)
  11. Frontporch
    549
    128
    Nj
    I picked up two new bushings from the local dealer $2 each. Nice to not have to buy entire pin. Picked up a single use SIL-glyde brake lube. I also pulled the caliper mount off and removed the rubber grommets and sprayed the mount pin cavity with brake clean and wiped it up. Was generous with the lube and put it back together. All sides well and I remembered not to open the drivers door while I was doing the work
  12. Frontporch
    549
    128
    Nj
    Forgot to mention those caliper mount bolts were on crazy tight. Wound up using my floor Jack on a wrench to get them moving.
  13. Mendel Leisk
    42,330
    Torque spec is quite high on the caliper bracket hold-down bolts, 101 ft/lb’s.
