Replace Headgasket and Waterpump or new engine?
Discussion in 'Gen 3 Prius Technical Discussion' started by jr33zy, Sep 24, 2019.
  1. jr33zy
    jr33zy Junior Member
    24
    25
    Los Angeles
    Good afternoon,
    So i saw a check engine light on Saturday and went to autozone to pull a code.. got back a ECT sensor issue. Made an appointment on Monday but then didnt go in because the light went away... drove it on Monday. Overheat icon came on and off (2min).
    Got it to the dealership today and got this:
    "Replace engine water pump, remove and inspect cylinder head/ estimate for needed repairs (P0117- ENGINE COOLANT TEMPERATURE CIRCUIT LOW INPUT, P148F- ENGINE COOLANT PUMP OVER REVOLUTION LOW COOLANT LEVEL, ENGINE WATER PUMP FAULTY AND ENGINE FAILED ON BLOCK TEST ( SIGN OF BLOWN HEAD GASKET)) "
    they're quoting 4400 for the replacement or 7k for a new engine.
    I keep it serviced on time and dealership said that sometimes it just happens without warning.
    I guess i'm looking at what are my next options.
    Current mileage 167k . Drive 2k a month.
    TIA for any help or suggestions
  2. Mendel Leisk
    42,293
    I hadn't heard of a block tester; looked it up: it tests coolant for presence of exhaust gas. I had heard of that, just didn't know the term
    Block Tester® - Info and tips on using your Block Tester
    Leak down test is another to consider, to determine head gasket failure.
    Just from what I've been reading $4400 is a little steep for head gasket and engine coolant pump, maybe phone around. Other LA responders will likely chime in with alternative shop recommendations. @The Critic @JC91006 are a couple.
    Have you cleaned the Exhaust Gas Recirculation and Intake Manifold? It's not likely to help now, but just to give some more data points: it seems like neglected EGR and head gasket failure go hand-in-hand. :(
    SFO and jr33zy like this.
  3. The Critic
    The Critic Resident Critic
    3,193
    2,333
    CA
    Take your car to Avi’s shop - he is a member on here as well.
    I think his pricing for a HG replacement (if possible) is under $3K.
    https://yelp.to/qTKq/H7Zw75pIf0
    $4400 for HG and WP replacement is about right for a dealer. Up here, it is about $4K for the HG alone.
    I am at the other end of CA and I am not open for commercial business at this time.
    SFO, Raytheeagle and jr33zy like this.
  4. spiralhelix
    spiralhelix Active Member
    255
    220
    Illinois
    You have quite a few options. Your least expensive option will be to do the work yourself if you can. If that isn't an option or in your wheelhouse, find an independent shop. I think the HG cost will be somewhere down to the 2-2.5k range. is that $7K for a NEW new engine, or new to you used engine, because new to you used that REALLY high. That's more than Lexus charged us. Again, an independent shop can do a swap for less.
    Honestly i haven't decided if dealers being ignorant to the EGR issue is by design to have high-dollar jobs or to sell more cars, or because corporate tells them it's not a problem. They make a lot more money off those things than a periodic EGR cleaning bill.
    good luck with your decision.
    jr33zy likes this.
  5. JC91006
    16,935
    8,646
    Any mechanic that works on import cars will be able to swap another engine into the car. That's probably the best option. The car is no longer that special where you need to go to a specialize shop to do an engine swap
    jr33zy likes this.
  6. The Critic
    3,193
    2,333
    CA
    Most repair shops prefer multiple small repairs over a single large job (e.g. engine swap or HG r/r). Large jobs take a long time (and hog up a bay) so it is tough to keep a single tech on a large job without being distracted by smaller jobs. This is why large jobs can often take weeks.
    I also disagree on the EGR being the sole cause of the HG issue. It is simply speculation and wishful thinking by DIYers; there is no evidence that the two are fully connected.
    #6 The Critic, Sep 24, 2019
    jr33zy, CR94, JC91006 and 1 other person like this.
  7. Mendel Leisk
    42,293
    Interesting head gasket replacement video, though they cut a lot of corners, and have cringe-worthy table manners. For example, you can see road grit just about to fall into the zone under the valve cover:
  8. The Critic
    3,193
    2,333
    CA
    That timing cover is also going to seep. If you spread rtv like peanut butter, there is no guarantee that you will have a sufficient, uniform film. Apply a bead and allowing the two surfaces to squeeze out the excess is the proper method.
    1:40 in this video demonstrates the correct method of application:
    SFO, Mendel Leisk and Raytheeagle like this.
  9. Mendel Leisk
    42,293
    Too, in the video I posted, the sealant is already applied to the timing chain cover, when they start filming. They stand there talking about for a while. This drives me nuts, like a fridge door left open: the sealant is supposed to be completely applied and the cover back on by +3 minutes, and all the bolts torqued by +15 minutes.
    All that said, it's an interesting video.
  10. jr33zy
    24
    25
    Los Angeles
    DUDE I JUST HAD MY CAR TOWED THERE FROM THE DEALERSHIP THIS AFTERNOON!!! thanks man!
    The Critic likes this.
  11. jr33zy
    24
    25
    Los Angeles
    no i just learned about the EGR. I've been just doing the normal oil changes, and suspension stuff. I really wished i stayed up on this forum and things like the EGR cleaning.
  12. jr33zy
    24
    25
    Los Angeles
    Thank you i brought it to Avi's shop Hybrid Fix in DTLA. he's going to post a video of the HG test and we will go from there.
  13. Greenteapri
    Greenteapri Active Member
    330
    388
    Cypress
    Update?
    jr33zy likes this.
  14. spiralhelix
    255
    220
    Illinois
    How did the Flying Spaghetti Monster find it’s way here?!?!?!? Hahaha
    -Spiral
    Greenteapri likes this.
  15. Greenteapri
    330
    388
    Cypress
    He's everywhere and know where. Lol
    spiralhelix likes this.
  16. jr33zy
    24
    25
    Los Angeles
    Defect in the waterpump! Crack made it so it wouldnt spin. Thanks Avi and crew at Hybrid Fix. Attach36603_20191009_134306.jpeg
  17. jr33zy
    24
    25
    Los Angeles
  18. mjoo
    mjoo Senior Member
    1,163
    1,334
    Michigan
    So, headgasket replacement wasn't needed then?
  19. jr33zy
    24
    25
    Los Angeles
    Nope.
    Raytheeagle, Greenteapri and mjoo like this.
  20. Greenteapri
    330
    388
    Cypress
    I love a happy ending. In more ways than one ;););)
    Raytheeagle likes this.
