Replace Headlight Bulb
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Rickame, Jun 25, 2016.
  1. Rickame
    Rickame Junior Member
    Eliot, Maine
    I just bought a used 2006 Prius with 157K miles. The headlights seem to be working, but I did notice one off in the driveway when I turned them on and off once. Does that mean one is going bad or is bad. The man I bought the car left a set of new HID bulbs (probably aftermarket) that he said he was going to install (he liked the blueish tint they had). My question, these bulbs are D2S. The manual says my car takes D4R. Will these fit. I've read about but unclear (projection vs reflection, mercury or not, etc.) but unclear if D2S can fit in my car. Any thoughts on using these or not, or what and where to get correct bulbs for reasonable price.
  2. S Keith
    S Keith Senior Member
    799
    328
    AZ
    2003 Prius
    HID bulbs fail slowly and in the manner you describe. You can google if a D2S will fit a D4R just as well as I can. Personally, I would just buy D4R.
  3. Rickame
    Eliot, Maine
    Thanks...I will replace with D4R...Did google but really coudn't find a clear answer if a D2S will work...No matter. Thanks again
  4. insaner
    insaner Junior Member
    96
    Atlanta, GA and Huntsville, AL
    Replacing them is a pita. I have to turn mine on and off about 5 times but they stay in after that.
  5. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    You should both see and read this: Not all HID Bulbs are created equal | PriusChat
    It answers why the bulb doesn't light immediately sometimes, why this is bad "insaner", and what bulbs to use for what model years.
    insaner likes this.
